Forum >romeo v2 and mitsumi m42sp-4n
userHead infobarque 2013-06-14 13:32:35 4884 Views5 Replies
hi,
sorry for my poor english
since 2 days I try to connect a stepper motor mitsumi m42sp-4n 5wires to pilot an astro.
I does it with a uln 2003 and arduino, but I can't do work with the romeo v2
it's a 12v motor wit the common on yellow wire.
I try all possibilities, but the motor turn in mode cube :(
if someone realise that, I'll be very happy
thank's for the help
2013-06-17 23:57:26 Hi Lumi,
sorry  :-\
translate with google
the working code with the m45sp-4n and a ul2003
[url=http://www.ecs.umass.edu/ece/m5/tutorials/stepper_motor.html]http://www.ecs.umass.edu/ece/m5/tutorials/stepper_motor.html[/url]
I modified the code to 4-5-6-7 and made a loop to replace potValue = analogRead (potPin);
M1=>4
E1=>5
M2=>6
E2=>7
but the motor doens't work, it just vibrates as if a wire was disconnected or reversed with another wire.
userHeadPic infobarque
2013-06-17 21:05:46 Hi infobarque,
I am also not quite sure what your problem is. Please post some pictures of YOUR setup and the code you are using to control the stepper.
Regarding to language mistakes please post the next time in English AND in your native language (i believe it's French), so we can figure out the problem better and find a solution.
userHeadPic lumi
2013-06-17 01:43:14 hi,
I see that nobody have an idea for this mitsumi  :-\
2013-06-14 23:31:25 hi,
the mitsumi is in most of old scanners
[url=http://www.danielstolfi.com/recursos/M42SP-4.pdf]http://www.danielstolfi.com/recursos/M42SP-4.pdf[/url]
[url=http://forum.arduino.cc/index.php?topic=146709.30]http://forum.arduino.cc/index.php?topic=146709.30[/url]
epoch motor is like mitsumi
2013-06-14 19:47:12 hello infobarque
Do you have some links we could refer to?
link to the motor, uln 2003 and so on?
some pictures would help as well
userHeadPic Jose
