Change APC220 settings
The user guide for the APC220 says there are 2 ways to change settings in the APC220 (freq, baud, etc.). One way is to use RF-Magic, and the other is to send ASCII commands through serial after drawing SET low. Does RF-Magic change setting with the SET pin? I didn't think RF-Magic had access to the SET pin.
2013-08-16 23:55:12 Hi abqlewis,
Yes, when the second one change setting, it will draw SET low first. Grey.CC
