Forum >Digital Servo Shield for Arduino (DRI0027) API
userHead immolator 2013-11-07 03:01:26 4182 Views3 Replies
I would like to extend the ServoCds55 Arduino library used by the above servo shield so it supports a read status operation for the AX-12 servos.
I looked at the ServoCds55.cpp file but it isn't using the standard AX-12 command set (the ones that start with 0xFF). Is there any doco on the command set it is using?
Thanks,
Craig
2013-12-14 00:05:13
The slave code its on the product description page since today, and it's using AX-12 standard command, it might help for reference.
[url=https://www.dfrobot.com/image/data/DRI0027/Slave%20code%20for%20deeper%20development.zip] download link [/url]
Why do you want to use the read status operation?
userHeadPic Jose
2013-12-13 19:05:01 the manual link is here:
[url=https://www.dfrobot.com/image/data/DRI0027/CDS55xx%7F%20Robot%20Servo%20User%20Manual.pdf] manual[/url]
userHeadPic Jose
2013-12-13 03:41:13 Hello there !
I'm wondering the same thing, did you find any doc ?
userHeadPic Sephius
