Forum >I2C 1602 LCD not working
userHead pavgud 2011-05-08 02:57:13 13857 Views19 Replies
I have problem making this I2C LCD (http://www.dfrobot.c...&product_id=135) to work with netduino. I attached two photos to show the wiring (http://forums.netduino.com/index.php?/topic/1795-i2c-lcd-not-working/). I use the following code:
I2CDevice lcd = new I2CDevice(new I2CDevice.Configuration(0x27, 400));
int bytesTransferred = 0;
string hellow = "hellow";
System.Text.UTF8Encoding encoder = new System.Text.UTF8Encoding();
byte[] bytesToSend = encoder.GetBytes(hellow);
I2CDevice.I2CTransaction[] writeCommandAction = new I2CDevice.I2CTransaction[] {I2CDevice.CreateWriteTransaction(bytesToSend) };
bytesTransferred = lcd.Execute(writeCommandAction, 1000);
Debug.Print("TRANSF> " + bytesTransferred.ToString());
Debug.Print("TOSEND> " + bytesToSend.Length.ToString());
I tried this code (http://code.tinyclr....lcd1602-module/) as well but without success.
When I connect USB to netduino, display's light powers on and the first line can be seen (Powered.jpg). Beyond that nothing happens.
2013-07-06 02:36:27 and what is pavgud? userHeadPic L_JESSIE
2013-07-06 02:22:54 Hi.
I'm not familiar with Netduino.but i want to try it.
And you can give me more information about your board.
I probably need some days to try.Would you mind?
2013-07-05 23:13:24 Hey,
thanks for your answers!
The pontimeter are not the Problem :( i have try it..
On my Arduino it works fine but i wont to run it on my Netduino like pavgud.
Thats actually my problem :(
userHeadPic bi0s
userHeadPic bi0s
2013-07-05 20:15:37 [quote="bi0s"]
I have the same Problem :( Can you please make a Screen and publish a litte example code ?
[/quote]
Hi,you can try this code.
[url=https://www.dfrobot.com/wiki/index.php/I2C/TWI_LCD1602_Module_(Gadgeteer_Compatible)_(SKU:_DFR0063)]https://www.dfrobot.com/wiki/index.php/I2C/TWI_LCD1602_Module_(Gadgeteer_Compatible)_(SKU:_DFR0063)[/url]
And not forget download The Arduino I2C LCD library.You can download it on this page.
[url=http://wiki.dfrobot.com.cn/index.php/(SKU:DFR0063)IIC_LCD1602_display_module_%E5%85%BC%E5%AE%B9Gadgeteer]http://wiki.dfrobot.com.cn/index.php/(SKU:DFR0063)IIC_LCD1602_display_module_%E5%85%BC%E5%AE%B9Gadgeteer[/url]
Hope you can succeed.
[/quote]
2013-07-05 19:54:20 i agree with alnath, try adjusting it with the potentiometer (blue box) on the back of the LCD. and see if it works better.
If it is I2C problem, I suggest you try some I2C scanner script to see if it is found. I'm not familiar with Netduino, but it would be good to check if is still not working, wether or not the LCD is on the same I2C bus
userHeadPic Jose
userHeadPic Jose
2013-07-04 13:18:15 it seems to me that it is a contrast adjustment problem userHeadPic alnath
2013-07-03 23:52:44 I have the same Problem :( Can you please make a Screen and publish a litte example code ? userHeadPic bi0s
2012-10-16 12:04:35 Hi, how did you solved your problem with the 1602 I2C LCD display? I have the same problem and don't know the solution. The same problem even after connecting GND and VCC. Even without SCL and SDA. userHeadPic looserko
2011-05-08 02:59:28 Here are the photos of wiring with netduino. userHeadPic pavgud
2011-05-08 02:57:13 I have problem making this I2C LCD (http://www.dfrobot.c...&product_id=135) to work with netduino. I attached two photos to show the wiring (http://forums.netduino.com/index.php?/topic/1795-i2c-lcd-not-working/). I use the following code:
userHeadPic pavgud
