Forum >Cant connect Android with Bluno
Just bough Bluno with Accessory Shield to try to Android ADK but no luck. From a Galaxy S4 with Android 4.3 i have tried too much to connect without success. The Application see the BLE device, try to connect (connecting) and nothing. Documentation and example are almost inexistant, it s very hard and the only sketch it s quite a mess to read. Sketch has been uploaded.
Also I see v1.4 stamp on Bluno when documentation show BLE v1.6, but not download available. Also it s brand new Bluno received 2 days ago...
(PS even logged in and modifying a previous post requesting 3 security verification is overkilled)
2014-03-15 09:20:14 Hi Grey,
My Note 3 has Android version 4.3. What happens when I try to connect is the 'link' led is on, and it just stays on until I unplug the power (The reset button seems not to work this case )
Tonyok
Tonyok
Tonyok
2014-03-14 17:51:49 Hello Tony?
Which version ROM you are using now ?
It only supports Android 4.3 now.
Grey.CC
Grey.CC
Grey.CC
2014-03-14 13:47:32 Hello,
I just bought a Bluno V1.6 a few days ago, and I experienced the same problem. I installed the APK app on my Note 3, and it can see the Bluno, but cannot connect (it shows 'connecting' for a few seconds, then stops). I tried to replace the original firmware 1.6 ( Date modified is 01/16/2014) by the firmware 1.6 downloaded from [url=https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267.]https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267.[/url] The result is the same, even I tried with firmware 1.4. What can I do to resolve this problem? Thank you
By the way, another strange thing is I cannot install the original firmware that I backed up before.
Tony
Tonyok
Tony
Tony
Tonyok
Tony
Tony
Tonyok
Tony
2014-01-11 06:20:26 Hi there,
first of all, I am sorry for my bad English. I played a little bit with the Bluno and had no problems to connect it with an iPhone and Firmware 1.4 and 1.6. I used it in combination with the accessory shield 1.0. Unfortuneatly I have no Android phone for testing therefore I used am PC with BLE dongle and was also able to get paired with it.
So, generell functionality should be there. I was also able to connect it with an Dell XPS 10 (Windows RT 8.1) via "0000" as passcode.
Perhaps this might help you.
BR
Marco
Marco
BR
Marco
BR
Marco
Marco
BR
Marco
BR
Marco
Marco
BR
Marco
2014-01-10 13:53:53 :(
I've upgraded the firmware on my BLUNO, but can't get the android APK file to install. The android install complains about it being 'corrupt'
SpiderNZ
SpiderNZ
SpiderNZ
2014-01-08 00:41:00 Hello sbusso,
The new firmware 1.6 has been finished. Please check the wiki page.
[url=https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267]https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267[/url]
Feel terribly sorry for the inconvenience.
Grey.CC
Grey.CC
Grey.CC
2014-01-07 01:34:54 Hello sbusso?
I am sorry. Please take it easy.
We find it is because that the bottom Bluetooth document of samsung Galaxy series are not compatible.
And we are making efforts on it now.
Grey.CC
Grey.CC
