Forum >How to power Girl Board from 9v
It says here "Input Voltage limits: 6.5-12V"
[url=http://www.dfrobot.com/index.php?route=product/product&product_id=1049]http://www.dfrobot.com/index.php?route=product/product&product_id=1049[/url]
What are the contacts I have to connect voltage (not USB)?
2014-05-29 00:51:33 Hello,
Your schematic looks right. There is no Vin port on the board, it is 5V.
How do you want to connect power chip to the girl board? With a breadboard?
Grey.CC
2014-05-28 09:12:51 Because of your mistake give me an answer (advice)
I have GirlBoard, 7.2V battery and a pump.
Is my scheme right?
[img]
* "Motor out Terminal" is for pump [url=https://www.dfrobot.com/index.php?route=product/product&filter_name=pump&product_id=667]https://www.dfrobot.com/index.php?route=product/product&filter_name=pump&product_id=667[/url]
* Voltage Regulator is [b]L7805[/b]
agent-j.ru
Is my scheme right?
[img]
2014-05-27 18:47:54 Yeah, there is a little mistake.
After seeing your post, we have checked the schematic. The specification is not very suitable, especially the power supply. I am sorry for the carelessness.
What is your problem?
It is better to power the board from the USB port. But if you want to support it from "+5V" and "GND" port, you must make sure the power supply is no higher than 5v, or it will damage the MCU. As what you said, [quote]I have to use DC-DC buck converter[/quote], you could try this connection, but please care about the output voltage.
Grey.CC
2014-05-27 05:49:26 [quote="Grey"]
Hello, agent-j.ru
The operating voltage is 5V, you could power it from the usb directly.
It is OK.
[/quote]
I see that GirlBoard description was changed today. The description was wrong?
Because of this I'm having some problems and I have to use DC-DC buck converter
agent-j.ru
Hello, agent-j.ru
It is OK.
[/quote]
2014-05-26 18:53:02 Hello, agent-j.ru
It is OK.
Grey.CC
It is OK.
