Forum >Bluno firmwre 1.8 TWI I2C does not seems to work. I use the example iso1143 A
Its seems the i cannot get beyond Hello this mean could not talk to the device using i2C . I am connecting to the NFC device . I use a normal Uno and there is no problem but when i connect the Bluno it does not work
I connect to A4 SDA a5 SCL . whats wrong any one could help?
2014-08-13 01:18:56 Hey Kenneth,
Could you attach your sketch? and connection diagram?
I tried one Bluno with it I2C interface before, It worked well.
Grey.CC
2014-08-12 02:55:37 No did not plug anything else I plug in the same connector to an Uno and it work but when I connect to the bluno nothings . please help
kenneth22
2014-08-12 02:37:17 Welcome kenneth,
Bluno I2c should be same to UNO. Did you plug something else on the board?
Grey.CC
