Forum >Having trouble with 3-wire Serial LCD Module (Arduino Compatible)
userHead russel_wood@hotmail.com 2013-02-26 14:16:57 5515 Views6 Replies
Cant seem to get this up and running. I am having trouble understanding the explanation of the pinouts because the labeling is different from the wiki. If I followed the order the top right pin is 1, and below that is VDD, then is top middle pin RS(CS)? Is the middle bottom pin RW(SID)? Is the top left pin EN(CLK) cause it looks like it's labeled SID?
Even the demo code that comes with on the wiki wont compile. And that's before I even hook up screen.
Help please
2014-09-10 08:14:13 User Moment said he user u8glib with lcd12864 module and it worked. I am having problems and and evidently not allowed to personal contact. I would really like to find how he set this up, I find the data somewhat confusing, but I am a newbie.
Jim
userHeadPic alfiesty
2013-03-05 02:39:32 Thanks for the error message. I will check that. userHeadPic lumi
2013-03-04 12:43:13 Well actually I never could get the example from DFRobot to work. I used the U8glib and I was off to the races.
The pins are all set in the library but when I compile I get this error...
sketch_mar03a.cpp.o: In function `loop':
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:33: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:33: undefined reference to `LCD12864R::CLEAR()'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:34: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:35: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:35: undefined reference to `LCD12864R::DisplaySig(int, int, int)'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:36: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:37: undefined reference to `LCD12864R::DisplayString(int, int, unsigned char*, int)'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:38: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:39: undefined reference to `LCD12864R::DisplayString(int, int, unsigned char*, int)'
sketch_mar03a.cpp.o: In function `setup':
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:25: undefined reference to `LCDA'
C:\Program Files (x86)\arduino-1.0.3/sketch_mar03a.ino:25: undefined reference to `LCD12864R::Initialise()'
userHeadPic russel_wood@hotmail.com
2013-02-27 17:31:22 Ok, good to hear. But would you mind to share what went wrong? My first guess was that you had some wrong in the code or/and the library was not installed. userHeadPic lumi
2013-02-27 12:07:24 Problem solved. I fixed it with stick-to-it-tiveness!!!!
2013-02-26 21:47:33 Please post a picture of the module itself and the error message that we can corner your problem. userHeadPic lumi
