Forum >Smart Servo Shield For Arduino not work ?
userHead middle 2014-10-04 05:50:49 3036 Views3 Replies
I just want to know why i can't make work my Servo Motor on this "Shield" .
I tried to implement the "example" code you share on your webSite here.
[url=http://www.dfrobot.com/wiki/index.php/Digital_Servo_Shield_for_Arduino_SKU:DRI0027]http://www.dfrobot.com/wiki/index.php/Digital_Servo_Shield_for_Arduino_SKU:DRI0027[/url]
Of course i already downloaded and imported with succes the library "ServoCds55 Library" at this link :
[url=http://www.dfrobot.com/image/data/DRI0027/ServoCds55%20Library.zip]http://www.dfrobot.com/image/data/DRI0027/ServoCds55%20Library.zip[/url]
After i plug the servo motor "Dynamixel AX-12A" => normally supported by this "Shield".
And i plug a power battery "LynxMotion 11,1V - 3800 mAh" directly on the Shield.
Like on this picture:
[img]
this full picture here =>
[url=http://imageshack.com/f/pbU6kTMTp]http://imageshack.com/f/pbU6kTMTp[/url]
When i start the code, nothing happen . I can not change the position of my servo..
Do you have some idea why my servo motor don't work ?
I really hope you can help me.
2017-08-09 03:52:49 Yes i confirme with sending a message like "p" . It's work. sometimes i need send 2 times for make it work one time. But it's can work userHeadPic middle
2014-12-10 09:04:31 you have it running already? You need to sent it some characters like "p" via the serial monitor. userHeadPic pcdewolff
2014-10-07 22:41:14 No people can help me ?
Up please  :'(
userHeadPic middle
