Forum >SIM800C GSM/GPRS Shield V2.0 library
I'm wondering if the library linked to the SIM808 GPS/GPRS/GSM Shield For Arduino
(https://github.com/DFRobot/DFRobot_SIM808)
will work with the SIM800C shield?
Based on SIM808_Serial_AT_Command_Manual_v1.07.pdf, the AT command set is the same for SIM808 and SIM800C.
2018-08-08 04:29:00 Thanks for the answer. I was able to get the shield work since then.
But I couldn't find on the Schematic, that exactly what pin is used from the UNO board to power the SIM800C GSM shield?
jordanits.arpad
2018-06-21 01:01:45 No. though the AT commands are same, they have different firmware which makes the library not compatible.
robert.chen
