Raspberry Pi 5 Starter Kit
$87.80
  • RAM
    4GB8GB
  • Power Supply
    EU StandardUS Standard
  • Cooling
    Aluminum CaseICE Tower CoolerFull-Metal CaseDual Fans Metal CaseActive Cooler
  • Add-on SD Card
    32GB64GB
  • Add-on Display
    7''10.1"15.6"
  • Essential Accessories
    720p8 Megapixels2 MegapixelsHDMI to Micro HDMIUPS HAT
  • Quantity
  • The Raspberry Pi 5 Starter Kit includes a single board computer (4GB/8GB), power adapters, cooling solutions, memory card options, HDMI cables, displays, and cameras.
    This Raspberry Pi 5 Starter Kit includes a Raspberry Pi 5 Single Board Computer (4GB or 8GB), power supply adapters for different regions (EU or US), cooling and enclosure solutions, memory card options for various storage needs, a high-quality HDMI to Micro HDMI cable designed specifically for Raspberry Pi, display options with a range of sizes and resolutions, and high-quality camera modules with additional features such as night vision or wide-angle lenses.
    Raspberry Pi 5 Single Board Computer 4G RAM / 8G RAM
    The Raspberry Pi 5 increases CPU performance by 2-3x, featuring a 64-bit quad-core Arm Cortex-A76 processor and an 800MHz VideoCore VII GPU for enhanced graphics.
    It offers state-of-the-art camera support, versatile connectivity options, and enhanced peripherals, making it the ideal solution for both consumer desktop experiences and industrial applications.
    5V / 5A Power Supply (EU / US)
    Optimize the Raspberry Pi 5’s performance with the power adapter, which provides a stable and continuous output of up to 5V/5A.” Safety assured with short circuit and overcurrent protection, UL and FCC certifications, and automatic resumption of operation after issue resolution.
    Raspberry Pi 5 Cooling Cases and Fan
    Aluminum Case
    Boost the Raspberry Pi 5’s performance with the Aluminum Heat Dissipation Kit, which features an adjustable-speed fan and a heat-dissipating copper sheet for efficient cooling. Ensure stability and reliability during high-performance operations with our lightweight yet strong aluminum case, designed specifically for the Raspberry Pi 5.
    Raspberry Pi 5 Aluminum Case
    ICE Tower Cooler
    Maximize Raspberry Pi 5’s performance with the Ice Tower-style RGB Cooling Fan, which features a high tower-type heat-sink and an adjustable-speed fan for efficient cooling. Ensure Raspberry Pi 5 runs smoothly with our cooling solution that prevents overheating, extends lifespan, and features a dazzling RGB light display for added visual appeal.
    Raspberry Pi 5 ICE Tower Cooler
    Full-Metal Case
    The Metal Heat Dissipation Kit features a heat-dissipating copper sheet, an adjustable-speed fan, and a metal case for optimal cooling.
    The kit provides excellent heat dissipation and automatic speed adjustment based on temperature.
    Raspberry Pi 5 Full-Metal Case
    The Dual-Fan Metal Case, made of aluminum alloy for effective protection and efficient heat dissipation. Features two adjustable-speed fans that automatically adjust based on the Raspberry Pi 5’s temperature, ensuring optimal operation and longevity.
    Raspberry Pi 5 Dual Fans Metal Case
    Cooling Fan
    The Cooling Fan designed for easy insertion and removal and equipped with self-locking fixing screws for quick installation.
    Raspberry Pi 5 Cooling Fan
    [Optional Items] Sandisk MicroSD Memory Card (32GB / 64GB)
    Get the most out of your smartphone, tablet PC, miniPC, and Raspberry Pi with this microSD memory card. This high-performance memory card features read speeds of up to 98 MB/s for transferring music, photos, and videos and is UHS-1 enabled to capture Full HD video. Waterproof, temperature proof, magnet proof, and X-ray proof, this reliable memory card ensures your files remain safe during life's little mishaps. An included SD adapter lets you use the card with your devices.
    [Optional Items] 4K HDMI to Micro HDMI Cable
    The 4K HD resolution Micro-HDMI video cable features a 19-core shield and gold-plated interface for stable transmission and durability, ensuring reliable performance even through multiple plug-ins and bends.
    [Optional Items] Display (Choose one out of three)
    15.6 Inch 1920x1080 IPS Type-C Touch Screen & Display
    This 15.6-inch capacitive touch display boasts a high resolution of 1920x1080, full-function Type-C and HDMI dual display interfaces, and supports ten-point capacitive touch. Offers wide compatibility and easy integration, suitable for LattePanda series, Raspberry Pi 4B, Jetson Nano, as well as various desktop computers, laptop computers, mini PCs, industrial computers, and tablet computers.
    10.1" Diagonal - 1280x800 IPS HDMI / VGA / AV Display
    This 10.1-inch IPS display, designed specifically for LattePanda and Raspberry Pi, features HDMI/VGA/AV interfaces for wide compatibility. It offers a screen size of 10.1 inches, a resolution of 1280x800, and supports audio output, making it an ideal choice for various mini PC applications.
    10.1
    7'' HDMI Capacitive Touchscreen
    This 7” HDMI Capacitive Touchscreen features up to 5 touchpoints and DFRobot USB free-driver technology for easy plug-and-play functionality.
    Supports Windows, Linux, and MAC OS, and is compatible with LattePanda, Raspberry Pi, and other HDMI devices, offering versatile use and easy mounting options.
    [Optional Items] Camera (Choose one out of four)
    Megapixel 720p USB Wide-angle Camera
    This Megapixel 720p USB Wide-angle Camera features a 140-degree viewing angle, plug-and-play functionality, and is compatible with the Raspberry Pi and NVIDIA Jetson Nano.
    The camera supports a variety of applications including face recognition and remote teaching, and offers adjustable parameters for optimal image capture.
    8 Megapixels USB Camera
    This 8 Megapixels USB Camera features autofocus, a digital microphone, and is compatible with multiple systems including Raspberry Pi and Jetson Nano.
    The compact camera supports various resolutions and frame rates, adjustable parameters for optimal image capture, and can be embedded into various devices, making it ideal for high-quality video systems, biometrics recognition, and industrial photography.
    2 Megapixels USB Night Camera
    This 2 Megapixels USB Night Camera features manual focus, interchangeable lens, and can bring HD photos and video even in low light conditions. It is compatible with multiple operating systems.
    The camera comes with a digital microphone for sound capture, supports various resolutions and frame rates, and is designed for easy use with Raspberry Pi and Jetson Nano mainboard.
    18650 Battery UPS HAT (5.1V 5A)
    The UPS expansion board for Raspberry Pi 5 provides stable 5V output, intelligently monitors power status, and auto-switches to UPS during power outages. It powers on automatically when power is restored, supports software shutdown, I2C battery level detection, and fast charging. Ideal for mobile power supply in various applications like smart cars and outdoor setups.
    $87.80
