Discontinued
Note: WiDo - An Arduino Compatible IoT (internet of thing) Board is discontinued now.
Wido is an Arduino compatible WIFI IoT Node development board, which integrates with WG1300 WIFI solution. The microcontroller of Wido is ATMEL ATmega32U4.
Wido is compatible with copious amounts of Arduino boards and periphery modules. You can implement it on M2M Sensor Node development, Toys, Gaming, Smart Home Device and many other applications.
DFRobot Microcontroller Selection Guide | ||||||||
Picture |
Model | DFRduino UNO | DFRduino Leonardo | DFRduino Mega2560 | DFRduino Mega1280 | Romeo V1 | Romeo V2 | Bluno | Wido |
SKU | DFR0216 | DFR0221 | DFR0191 | DFR0003 | DFR0004 | DFR0225 | DFR0267 | DFR0321 |
Processor | ATmega328 | ATmega32u4 | ATmega2560 | ATmega1280 | ATmega328 | ATmega32u4 | ATmega328 | ATmega32u4 |
Board Type | Arduino UNO | Arduino Leonardo | Arduino Mega 2560 | Arduino Mega | Arduino UNO | Arduino Leonardo | Arduino UNO | Arduino Leonardo |
Operating Voltage (Voltage / Input Voltage) | 5 V/7-12 V | 5 V/7-12 V | 5 V/7-12 V | 5 V/7-12 V | 5 V/7-12 V | 5 V/7-20 V | 5 V/7-12 V | 5 V/7-12 V |
CPU Frequency | 16MHz | 16MHz | 16MHz | 16MHz | 16MHz | 16MHz | 16MHz | 16MHz |
Analog Ports (Input / Output) | 6 / 0 | 12 / 0 | 16 / 0 | 16 / 0 | 6 / 0 | 12 / 0 | 6 / 0 | 12 / 0 |
Digital Ports (IO/PWM) | 14 / 6 | 20 / 7 | 54 / 15 | 54 / 15 | 14 / 6 | 20 / 7 | 14 / 6 | 20 / 7 |
EEPROM[KB] | 1 | 1 | 4 | 4 | 1 | 1 | 1 | 1 |
SRAM[KB] | 2 | 2.5 | 8 | 8 | 2 | 2.5 | 2 | 2.5 |
Flash[KB] | 32 | 32 | 256 | 128 | 32 | 32 | 32 | 32 |
USB Interface | A-B | Micro | A-B | A-B | A-B | Micro | Micro | Micro |
UART | 1 | 2 | 4 | 4 | 1 | 2 | 1 | 2 |
Dimension | 75 × 55mm | 75 × 55mm | 108 × 54mm | 108 × 54mm | 100 × 80mm | 89 × 85mm | 75 × 55mm | 75 × 55mm |
Price | $19.90 | $19.90 | $24.90 | $14.00 | $29.50 | $34.95 | $24.90 | $29.90 |
Features |
*Designed for domestic Arduino fans. Full compatible with Arduino UNO R3.
*Suitable for Arduino Beginners.
*Low-cost mian controller board. The main difference from the official one is that this board offers XBee socket and SPI directly-plugged interface, making the best of UART ports.
*For low-cost project, and Arduino compatible communication module development.
*DFRduino Mega 2560 comes with plenty of IO ports, 54 digital ports, 16 analog ports, and 4 UARTs.
*Applicable to large projects that requires many sensors.
*Mega1280 has as many IO ports as Mega256, but comes with a smaller Flash. Besides, its price is lower than Mega2560.
*Suitable for low-cost projects requiring many sensors.
*Romeo V1 is specially designed for robot fans. It integrates motor driver, all sorts of communication ports, IO expansion port and so on.
*Extremely suitable for robot fans.
*The only difference between V1 and V2 is that Romeo V2 adopts ATmega32u4 chip, which provides 2 UARTs, convenient for wireless communication.
*For robot fans to build up projects with wireless communication.
*The first Arduino compatible controller board that integrates Bluetooth 4.0, bring much more flexibliy and possibility for Android and IOS mobile development.
*For Android and IOS mobile App BLE developers.
*Integrated CC3000 wifi core and SD card function. Can store a large number of collected data. Compared with Wifi shield, wido is more lightweight and low-cost.
*For IoT developers.
Como actualizar el firmware de Wido Node IoT, ejemplo de uso y revisión
(HOW TO UPDATE THE FIRMWARE OF WIDO NODE IOT, EXAMPLE OF USE AND REVISION)
WIDO WiFi IoT Node by dfrobot.com - Install lib and first example
Review of WIDO WiFi IOT Node by dfrobot.com
INTERNET OF THINGS AT YOUR FINGERTIP
TALK TO THE CLOUD. REINVENT THE HOTTEST SMART DEVICE.
DESIGN THE NEXT BIG ONE. SOLVE YOUR UNIQUE PROBLEM.
