Pirate: 4WD Mobile Robot Kit for Arduino with Bluetooth 4.0 (Discontinued)
SKU: ROB0022
Discontinued
Note: Pirate: 4WD Mobile Robot Kit is discontinued now.
Pirate: 4WD Mobile Robot Kit for Arduino with Bluetooth 4.0 is an Arduino compatible and Bluetooth 4.0 (BLE) ready robot kit with a set of Ultrasonic sensors (URM37). It allows you to build a fully autonomous mobile robot. This kit has great potential that over 200 DFRobot Gravity sensors and modules are available to expand the capability. It is a good educational robot kit for K12 robot class and STEM education.
The DFRobot 4WD mobile robot Platform is intended for use with the DFRobot ROMEO All-in-one Controller and includes 4x motors, 4x wheels, and a complete chassis with mounting hardware. The included second level allows you to add more electronics and define a modular layout. The rectangular hole allows for a servo to be attached and be used for several purposes like a movable camera or a robotic arm. The high-strength aluminum alloy body material provides flexibility in rapid movement particularly in outdoor grass, gravel, sand, or sloped surface. The increased life span of the electronics and gears due to the chassis study structure. The Pirate: 4WD Mobile Robot Kit for Arduino with Bluetooth 4.0 is also suitable for robot competitions and research-related projects.
A variety of sensors can be easily added and kept protected from external damage. The bottom sturdy case keeps the motors and battery pack protected to avoid fall damage. If you have built from salvaged parts before, you can tell the difference from a high-strength aluminum alloy that holds parts together and is tailored for sensors and electronic assembly.
How to Assemble this DFRobot Pirate 4WD Mobile Platform?
How to make an obstacle avoiding robot - DIY
  • Microcontroller: Romeo BLE
  • Controller Operating Voltage: 5V
  • Ultrasonic Sensor Detecting range: 5cm-500cm
  • Rotation range: 0 - 180
  • Power Supply: 7.5 ~ 12V DC
  • Speed: 90cm/s
  • Dimensions: 200mm x 170mm x 105mm (7.9x 6.7x 4.1 in)
  • Weight: 1020g
Optional Parts
How To Build A Robot - Lesson 7:Build A Bluetooth-Controlled Arduino Robot
Blog How To Build A Robot - Lesson 7:Build A Bluetooth-Controlled Arduino Robot
Dec 28, 2016
How To Build A Robot - Lesson 5: Build An Arduino Robot With Light And Sound Effects
Blog How To Build A Robot - Lesson 5: Build An Arduino Robot With Light And Sound Effects
Dec 17, 2016
How to Build a Robot – Lesson 1: Introduction
Blog How to Build a Robot – Lesson 1: Introduction
Nov 12, 2016
