Gravity: Beginner Kit for Raspberry Pi 2 (Windows 10 IoT Compatible)(Discontinued)
SKU: KIT0103
Discontinued
Gravity: Beginner Kit for Raspberry Pi 2 (Windows 10 IoT Compatible) is discontinued now. We recommend Raspberry Kits as replacement where you might find other products interested.
This is the basic Raspberry Pi 2 Model B development kit designed for Windows 10 IoT Core OS. The second generation Raspberry Pi is more powerful than its predecessor, with an ARM Cortex-A7 quad-core CPU. This gives it a lot more exciting capabilities that can be used with this kit, including being able to run a scaled-down Windows 10 system.
The IoT beginner kit comes with basic sensor modules such as push buttons, LED modules, temperature sensors, light sensors, rotation sensors and soil moisture sensors. Using the Pi's integrated WiFi module makes it possible to connect to the Microsoft's "Azure" Cloud service easily where you can upload your sensor data to the database.
After learning how sensors work, you can build simple applications such as indoor temperature alarms or fire alarms. The relay module even gives you the ability to turn devices on and off remotely in your home, office or garden. You can set up a device to turn on all the lights in your house at a certain time. Why not set up a machine to feed your fish when they are hungry? When your plants are thirsty, water them automatically! There are many fun applications for this kit. Experience the magic of Windows 10 IoT!
Check out the tutorial for some cool project ideas based on this kit.
Setting Up the Raspberry Pi 2
  • An affordable and easy to build IoT system
  • Abundant open source software available on the Github
  • Use Microsoft Visual Studio 2015 to develop software
  • Compatible with hundreds of different sensors
  • Wide range of expandible sensors
  • Raspberry Pi 2 Module B
  • Broadcom BCM2836 900MHz quad-core ARM Cortex-A7 CPU
  • 1GB LPDDR2 SDRAM
  • 4 x USB 2.0
  • Video out via HDMI, 3.5mm A/V Jack or Raw LCD (DSI) interface
  • Audio Out via 3.5mm A/V Jack or Audio over HDMI
  • Audio In via Camera interface
  • Storage: Micro SD Slot
  • 10/100 Ethernet (RJ45)
  • Low-Level Peripherals:
    • 26 x GPIO
    • UART
    • I2C bus
    • SPI bus with two chip selects
    • +3.3V
    • +5V
    • Ground
  • Power Requirements: 600mA up to 1.8A@5V via MicroUSB or GPIO Header
  • Arduino Expansion Shield for Raspberry Pi B+
    • Onboard Microcontroller: ATmega32u4
    • Arduino Leonardo Chip
    • Arduino Compatible pin mapping
    • Compatible with Arduino compatible shields and sensors
    • System Voltage: 5V
    • Arduino Digital I/O: 20
    • Arduino Analog I/O: 6
    • Raspberry Pi B+ GPIO: 16
    • Raspberry Pi B+ I2C: 1
    • Raspberry Pi B+ ID_I2C: 1
    • Raspberry Pi B+ SPI: 1
    • Raspberry Pi B+ TTL UART: 1
