Discontinued
This product is discontinued. Please refer to below replacement:
This aluminum alloy heat sink is designed for LattePanda 2 Alpha and 2 Delta Single Board Computer. While perfectly protecting the motherboard, the case reserves all peripheral interfaces and GPIO of LattePanda, which allows you to DIY projects of all kinds as much as you like. The aluminum alloy case has good thermal conductivity, and can also be accompanied by high-quality Shintsu X2379215CPU silicone grease and copper heatsink to make the heat dissipation effect more remarkable.”
Four external fan holes are reserved on the housing, so you can conveniently add a fan on it, such as 4010, and 4012 fans. (Recommended Fan Dimension: 40 x 40mm with 32 ±0.3mm hole, M3 screws)
Note:
1. Please remove the pre-installed cooling fan on LattePanda Alpha or Delta when using the Aluminum Alloy Case.
2. For your safety, please DO NOT touch the case directly during use to prevent burns.
3. It is normal that the copper heatsink goes black after being used for a long time; Those who mind can polish it with sandpaper.
Aug 02, 2024
It works as expected. I wish it came with a fan, but I got a fan for it after the purchase.
Nov 25, 2020
Very sturdy and definitely beautify: D
