12.5" 4K IPS Touch Display (Compatible with Raspberry Pi 4B / LattePanda Alpha / Delta) (Discontinued)
SKU: DFR0698
Discontinued
This product is discontinued. Please refer to below replacement:
Note: 1. This touch display is compatible with Raspberry Pi 4B & LattePanda 2 Alpha / 2 Delta / 3 Delta / Sigma, but not compatible with LattePanda V1.
2. The black power adapter or white power adapter will be shipped randomly.
This 12.5”4K IPS Touch Display is most suitable for Raspberry Pi 4B. It supports up to 10 touch-points, no breakpoints, bringing you an extremely smooth experience!
The screen supports two major operating systems Windows and Linux and can be used for Raspberry Pi and other devices with HDMI output, such as LattePanda Alpha , LattePanda Delta and LattePanda 3 Delta.
Touch Display with LattePanda
It is recommended to use the LattePanda original power adapter for power supply. The white adapter that comes with the display cannot supply power for both the display and LattePanda.
12.5
12.5
Wiring operation order of the screen and mainboard: 1. HDMI  2. Power supply  3. USB
The display screen adopts low blue light and flicker-free technology, which could take good care of your eyes. Apart from that, this display also employs 3840 * 2160 high resolution and HDR high dynamic image rendering technology that enables the device to present you all the details with more vivid colors and the stark contrast of light and shadow, restoring the real world on a 12.5” screen. The IPS panel of the product offers 100% color gamut and 178° wide viewing angle to keep displaying natural, clear, and delicate pictures.
12.5 Inch 4K IPS Touch Display
Since the dual USB3.1 Type-C universal HMDI interfaces on the display support PD protocol, you no longer have to distinguish the power supply and data signal transmission interfaces, plug, and play. What’s more, the display has a MINI HMDI video port for connecting to Raspberry Pi, allowing you to view the display content on a large screen.
12.5
  • Display Dimension: 12.5”
  • Viewing Angle: 178°
  • Brightness: 400cd/㎡
  • Resolution: 3840*2160
  • Optical Properties: IPS-Pro
  • Refresh Rate: 60HZ
  • Color Gamut: 100%
  • Power Supply: Type-C
  • Material: CNC Aluminium Alloy
  • Product Size: 286*186*5.5(10)mm/11.3*7.3*0.2 (0.39)”
  • Weight: 556g
  • 12.5" 4K Touch Display x1
  • Double head type-C cable x2
  • Type-c to USB A cable x1
  • Mini HDMI to HDMI cable x1
  • Mini HDMI to Micro HDMI cable x1
  • Power Adapter(UL Certification) x1
  • Protective Cover x1
 LattePanda Delta Projects Overview
Blog LattePanda Delta Projects Overview
May 30, 2022
