24Mhz 8 Channel Logic analyzer (Saleae Logic Compatible)(Discontinued)
SKU: DFR0178
Discontinued
This 24Mhz 8 Channel Logic analyzer is discontinued now, Please go the DFRobot homepage to see other products.
This is a very affordable 24Mhz 8 Channel USB Logic analyzer. This is a hobbyist level analyzer, ideal for testing your Arduino or other hobbyist microcontroller's communications. A logic analyzer is a must have tool for any serious electronics hobbyist. With a logic analyzer it is possible to see a visual representation of the zeros and ones that are flashing by between two components. A logic analyzer is different from an oscilloscope because the analyzer allows you to capture the data on a PC for a more detailed analysis of the data which is being transmitted and received. This logic analyzer supports 10 different communications standards (see Specifications below). with 8 channels it will allow you to monitor upto 8 differnet wires. So on an Arduino you could monitor the Serial port (tx/Rx pins), the I2C port (pins A4, A5), and the SPI port (pins 10, 11, 12, and 13) all at the same time.
  • 8 Channels
  • Supports triggering (rising, high, falling, low)
  • Up to 24Mhz sampling
  • Up to 10 Billion samples
  • Max Voltage: 5.25Vdc
  • supports:
    • CAN
    • DMX-512
    • I2C
    • I2S/PCM
    • Manchester
    • 1-Wire
    • Async Serial
    • Simple Parallel
    • SPI
    • UNI/O
    • Fully compatible with the Saleae Logic software
  • Logic Analyzer x1
  • Mini USB Cable x1
  • Jumper wire x10
