OBDII UART Adapter(Discontinued)
SKU: TEL0066-A
Discontinued
This product works as a vehicle OBD-II data bridge for Arduino, providing OBD-II data access with Arduino library as well as power supply (converted and regulated from OBD-II port) for Arduino and its attached devices.
The adapter plugs into the OBD port usually located under the steering column or slightly to the left of it. To check if your vehicle is OBD-II certified, open your hood and find the sticker that looks like this:
Vehicles using following vehicle protocols are supported.
CAN 500Kbps/11bit
CAN 250Kbps/11bit
CAN 500Kbps/29bit
CAN 250Kbps/29bit
KWP2000 Fast
KWP2000 5Kbps
The OBD-II Adapter is compatible with Arduino models including Arduino UNO, Arduino Leonardo, Arduino Micro, Arduino Nano, Arduino Mini, Arduino Pro Mini, Arduino MEGA 1280/2560/ADK.
Please note that the 500mA/2.5W version is for cars with 12V battery (that is the case with most passenger cars).  For 24V battery, please check the adapter MK2.
  • Supporting CAN bus & KWP2000 vehicles
  • ELM327 command-set interface
  • Fast (up to 100Hz) read-out of OBD-II PIDs available in vehicle ECU
  • Accessing and clearing vehicle diagnostic trouble code (DTC)
  • Built-in voltage meter for measuring car battery voltage through OBD-II port
  • High efficiency DC-DC module providing attached devices with regulated DC 5V up to 2A
  • Serial UART data interface (baudrate adjustable, default 38400bps)
  • Arduino library and sketches provided
  • Size: 72x48x28 mm (2.83x1.89x1.10")
  • Cable Length: 1m (39.97")
  • OBD-II Adapter for Arduino - 2.5W  x1
