PROJECTS Arduino
Controlling of Servo Motor with Arduino and MPU6050
DFRobot Jul 15 2019 261970
In this tutorial we will get data from a MPU6050 Gyroscope and control a Servo motor according to the movement of MPU6050.
Things used in this project
Hardware components
Arduino UNO & Genuino UNO ×1
DFRobot 6 DOF Sensor - MPU6050 ×1
SG90 Micro-servo motor ×1
Arduino IDE
Story
Components
  • Arduino UNO
  • MPU6050
  • MG 996R Servo Motor
  • Jumper Wires
Connections
Check the attach diagram for connections
Note: You can also connect SDA and SCL pins of MPU6050 to A4 and A5 pin of Arduino respectively.
Programming
Include the attached library in your arduino IDE, then upload the code in your Arduino board.
Note
Check the video for complete understanding and subscribe our channel for more.
Thank You.
Schematics
Circuit Digram
Code
Code for ProjectC/C++     Click Here to Download
//hammadiqbal12@gmail.com //https://www.youtube.com/watch?v=Cvtr3LKdqvk #include <GY6050.h>           //library for GYRO #include <Wire.h> #include <Servo.h> Servo myservo;  // create servo object to control a servo int X = 0; int Y = 0; GY6050 gyro(0x68);              //to save GYRO data void setup() {  Wire.begin();            //initializing GYRO  gyro.initialisation();  delay(100);  myservo.attach(9); } void loop() {  X = map(gyro.refresh('A', 'X'), -90, 90, 0, 180);                //mapping the gyro data according to angle limitation of servo motor  Y = map(gyro.refresh('A', 'Y'), -90, 90, 0, 180);  myservo.write(Y);                                               //movement of Y axis will control servo delay(15); }
This article copied from hackster.io, Author: Hammad Iqbal
