Object detection is an important field in computer vision and artificial intelligence, allowing computer programs to "see" their surroundings by identifying objects in images or videos. With advancements in deep learning technology, the accuracy of object detection has reached unprecedented levels. There are now many cutting-edge object detection models to choose from. This article will introduce and compare several popular object detection models for the year 2024. Whether you are a developer of computer vision or machine learning applications, or simply an enthusiast in the field, this article will help you choose the right model for your next project.
Object detection models are a class of machine learning models designed to automatically detect, locate, and identify specific objects in digital images or videos. These models learn features from data using deep learning techniques and apply the learned patterns to new input images to predict which objects are present in the image, as well as their exact locations and bounding boxes.
Common object detection algorithms fall into four main categories:
Object detection models combine convolutional layers for feature extraction with specialized layers like Region Proposal Networks (RPN) or anchor-based mechanisms to generate bounding boxes of objects of interest. Additionally, these models often incorporate state-of-the-art techniques like Non-Maximum Suppression (NMS) to filter out redundant detections and improve overall detection accuracy.
These models can accurately and efficiently recognize objects in real-time, making them indispensable tools in applications such as autonomous driving, video surveillance, and object recognition.
Object detection models have applications in various fields, including:
Pokemon Go GIFs - Find & Share on GIPHY
Object detection is a key component in automating tasks, enhancing security, and improving the efficiency of interpreting visual data. It plays a crucial role in developing intelligent systems across various industries. Therefore, the accuracy and processing speed of object detection are important metrics for evaluating computer vision application models.
There are various open-source and commercial models available in the market, and the following are some top object detection models to watch in 2024.
YOLO (You Only Look Once) is a popular object detection model among computer vision and machine learning developers. YOLO adopts a revolutionary single-stage object detection approach by dividing the image into equally sized grids and predicting the presence of objects and their probabilities in each grid separately.
Developed by Joseph Redmon and continued by Ultralytics, YOLO represents a pioneering approach that combines speed and accuracy in object detection. YOLO treats object detection as a regression problem, directly predicting bounding boxes and class probabilities from input images in a single evaluation.
The main advantages of YOLO include:
The original YOLOv1 (2015) introduced this unified detection method. Subsequent versions have improved performance:
Although earlier versions like YOLOv3/v4 were once state-of-the-art, recent versions like YOLOv7/v8 have achieved top results in benchmarks like MS COCO while maintaining real-time speed suitable for applications like autonomous driving, surveillance, and robotics. YOLOv9, released in February 2024, introduced Programmable Gradient Information (PGI) and a lightweight GELAN architecture, significantly enhancing performance and applicable to a wide range of models from lightweight to large.
After the release of YOLOv9 in February, the baton of the YOLO (You Only Look Once) series passed to researchers at Tsinghua University in China.
At the end of May, YOLOv10 was launched. The research team proposed an overall efficiency-accuracy-driven model design strategy for YOLO, optimizing all components of YOLO from both efficiency and accuracy perspectives, greatly reducing computational costs and enhancing model capabilities.
Extensive experiments have shown that YOLOv10 achieves SOTA performance and efficiency across various model scales. For example, YOLOv10-S is 1.8 times faster than RT-DETR-R18 in AP on COCO, while significantly reducing parameter count and FLOP. Compared to YOLOv9-C, YOLOv10-B reduces latency by 46% and parameters by 25% while maintaining the same performance.
The simplicity, speed, and continuous improvements of the YOLO series have made it one of the most widely used and influential object detection frameworks to date.
Known for its efficiency and accuracy, leveraging EfficientNet as the backbone.
EfficientDet, proposed by researchers at Google Brain in 2020, is a state-of-the-art object detection model that achieves high accuracy while being highly efficient in terms of model size and inference speed.
The key ideas behind EfficientDet include:
The EfficientDet architecture works as follows:
EfficientDet models like EfficientDet-D7 achieve state-of-the-art accuracy on the challenging COCO dataset while being an order of magnitude smaller and faster than previous detectors like Faster R-CNN. They work well across a wide range of resource constraints like mobile devices.
The compound scaling method enables a simple way to scale up EfficientDet models for higher accuracy or scale them down for faster mobile deployment. This flexibility, combined with state-of-the-art performance, has made EfficientDet a popular choice for many object detection applications.
Introduces the Focal Loss to handle class imbalance.
RetinaNet, proposed by researchers from Facebook AI Research in 2017, is a highly efficient and accurate one-stage object detection model. It addressed several shortcomings of previous one-stage detectors like YOLO and SSD.
The key innovations in RetinaNet include:
The RetinaNet architecture works as follows:
RetinaNet achieved state-of-the-art results on the COCO benchmark when introduced, outperforming previous one-stage and two-stage detectors in accuracy while being faster than two-stage models. Its ability to robustly detect small and large objects made it suitable for various real-world applications.
While more recent architectures have advanced further, RetinaNet's impact stems from its elegant solutions to key challenges in one-stage detection, like class imbalance and multi-scale sensing. Its design principles of improving representation and supervision have influenced many subsequent object detectors.
A highly accurate model that uses Region Proposal Networks (RPN).
Faster R-CNN, proposed in 2015 by Shaoqing Ren et al., is a highly influential two-stage object detection model that significantly improved upon its predecessors like R-CNN and Fast R-CNN.
The key innovations in Faster R-CNN include:
The Faster R-CNN architecture works as follows:
Faster R-CNN achieved state-of-the-art object detection accuracy on benchmarks like PASCAL VOC and MS COCO when it was introduced, while being much faster than its R-CNN predecessors. Its two-stage design allowed precise localization of objects.
Despite being superseded by newer one-stage models like YOLO and SSD in terms of speed, Faster R-CNN laid the groundwork for many subsequent region-based CNN detectors. Its impact was amplified by influential follow-ups like Mask R-CNN (for instance segmentation) and its extensions to other vision tasks.
Faster R-CNN's accuracy and architectural innovations cemented its status as a landmark model that advanced the field of object detection and visual recognition.
An extension of Faster R-CNN that adds a branch for predicting segmentation masks.
Mask R-CNN, proposed in 2017 by Kaiming He et al., is an extension of the highly successful Faster R-CNN model for the task of instance segmentation. It not only predicts the bounding boxes around objects like Faster R-CNN, but also generates pixel-wise masks for each instance.
The key innovations in Mask R-CNN include:
The Mask R-CNN architecture works as follows:
A CNN backbone extracts feature maps from the input image.
A Region Proposal Network (RPN) proposes candidate object bounding boxes (region of interests or ROIs).
ROIs are pooled into fixed-size features using RoIAlign.
Parallel branches predict the class label, bounding box offsets, and a binary mask for each ROI.
Mask R-CNN achieved state-of-the-art results on the challenging COCO instance segmentation benchmark when introduced, significantly outperforming previous methods. Its ability to generate high-quality masks along with bounding boxes made it suitable for applications requiring precise instance segmentation.
Beyond instance segmentation, Mask R-CNN has been extended to other areas like human pose estimation (e.g., Mask R-CNN + Keypoint R-CNN), showing its versatility as a general framework for object detection and segmentation tasks.
Mask R-CNN's accuracy, robust design, and widespread adoption have solidified its status as one of the most influential models in the field of instance-level recognition and a key milestone in the development of advanced computer vision systems.
Uses transformers for object detection, providing a new approach to the task.
DETR, short for DEtection TRansformer, is a pioneering object detection model proposed in 2020 by researchers from Facebook AI Research. It was the first paper to successfully apply the transformer architecture to the object detection task in a simple and effective manner.
The key ideas behind DETR include:
The DETR architecture works as follows:
When introduced, DETR matched the performance of the well-established Faster R-CNN detector while being much simpler and more parallelizable. It showed transformers' potential for high-level computer vision tasks beyond image classification.
While DETR was slower than traditional detectors, it inspired a flurry of follow-up work improving its speed, accuracy, and extending it to tasks like panoptic segmentation. Deformable DETR, Efficient DETR, and Anchor DETR built upon its core transformer-based detection ideas.
DETR's powerful set-based global reasoning capability and seamless integration of auxiliary outputs like masks/keypoints enabled an elegant, unified vision transformer framework. Its impact goes beyond just object detection, sparking wider use of transformers for various vision tasks.
This article introduces several popular object detection models and compares them.
According to specific application requirements and hardware configurations, choosing the most suitable model can achieve the best balance between performance and efficiency.
If you are interested in the latest research advancements, you can also follow important conferences in computer vision and pattern recognition such as CVPR(Conference on Computer Vision and Pattern Recognition)and ICCV(International Conference on Computer Vision), where the latest advancements and new applications of object detection models are frequently released.
