SELECTION GUIDE DFRobotEnglish
Arduino Official Board Selection Guide
DFRobot May 29 2020 261867
Product Name
Arduino Uno Rev 3
Arduino DUE - An Arduino Microcontroller Board
DFRduino Leonardo with Xbee Socket (Arduino Leonardo Compatible)
Arduino Mega 2560 Rev3
Arduino Mega ADK - R3(Discontinued)
Arduino Micro RETAIL(Discontinued)
Arduino Yún- A New Arduino Microcontroller Board(Discontinued)
Figure
SKU
DFR0181
DFR0220
DFR0221
DFR0108
DFR0149
DFR0230
DFR0297
Processor
ATmega328
AT91SAM3X8E
ATmega32u4
ATmega2560
ATmega2560
ATmega32u4
ATmega32u4
Operating Voltage (voltage / input voltage)
5 V/7-12 V
3.3 V/7-12 V
5 V/7-12 V
5 V/7-12 V
5 V/7-12 V
5 V/7-12 V
5V
CPU Frequency
16MHz
84MHz
16MHz
16MHz
16MHz
16MHz
16MHz
Analog Ports (Input / output)
6 / 0
12 / 2
12 / 0
16 / 0
16 / 0
12 / 0
12 / 0
Digital Ports (IO/PWM)
14 / 6
54 / 12
20 / 7
54 / 15
54 / 15
20 / 7
20 / 7
EEPROM [KB]
1
1
4
4
1
1
SRAM [KB]
2
96
2.5
8
8
2.5
2.5
Flash [KB]
32
512
32
256
256
32
32
USB Interface
A-B
Micro
Micro
A-B
A-B
Micro
Micro
UART
1
4
2
4
4
2
2
Dimension
75 × 55mm
108 × 54mm
75 × 55mm
108 × 54mm
108 × 54mm
45 × 20mm
75 × 55mm
*Classical Arduino controller board, reference version of later Arduino Boards. *Suitable for Arduino beginners.
*Atmel SAM3X8E-based (32-bit ARM microcontroller) Arduino controller board. Note:unlike other Arduino boards, DUE only supports 3.3V operating voltage, which could be not compatible with 5V shields and peripheral devices.
*Low-cost, more analog and digital ports than UNO, 2 UARTs. *For low-cost Arduino projects.
*54 digital ports, 16 analog ports, much more IO ports. *Applicable to large project scenarios that need more sensors.
*Atmega2560-based controller board, fully compatible with Google ADK. *For realizing USB data communication with Android mobile system.
*A microcontroller based on Atmega32U4 , pretty small size, compatible with small breadboards. *Suitable for projects with size requirement.
*A controller board based on ATmega32u4 and Atheros AR9331. Atheros supports Linux-based branch of OpenWRT platform Linino system. *Applicable to developers who want to build up Arduino-based IoT projects.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
