Combo Breaker - Motorized Combo Lock Cracking Device with Arduino
Jun 08 2015260020
Combo Breaker is a motorized, battery powered, 3D printed, Arduino-based combination lock cracking device. It is portable, open source, 3D models provided, and exploits a new technique developed by Samy Kamkar for cracking combination locks in 8 attempts or less, but in an even more exciting, automated fashion.
Connect the combo breaker to any Master Lock, switch on, the breaker will automatically detects and opens the lock.
How does it work? Combo Breaker does not use simple exhaustive crack, instead it uses mathematical crack and anyone with a little training can break any a low-end Master Lock within 8 minutes. This technique takes advantage of the combination of a manufacturing defect: combination lock U lock on the rotor in the rotation will be pulled up, unlock the person can feel certain Numbers of resistance is different, can know the number plate position, know the digital combination lock. Plus Mr. Kamkar through mathematical decoding and encoding web tools, narrowing the scope of the password, it is easier to find out the password. In this manual decoding method is very simple, Ars Technica editors to test the method, the results through dozens of tests, most people solved the lock.
Point of Contact: @SamyKamkar // http://samy.pl
Avoid upcoming China tariffs! DFRobot's new California warehouse offers popular development boards, sensors, and kits with tariff-free US shipping. Shop now and save!
DFRobot is heading to Embedded World 2025 in Nuremberg, Germany, from March 11-13, and we’re bringing the latest in embedded computing, IoT, and industrial solutions.
This article introduces the Mind+(Mindplus) editor, which seamlessly combines block-based and text coding in its interface, facilitating an easier transition.
