PROJECTS Arduino
Arduino Project 9: Light Sensitive LED
DFRobot May 08 2017 265852
Arduino Tutorial 9: Light Sensitive LED
Let’s introduce a new sensor component: the photo diode. In simple terms, when the sensor detects light, its resistance changes. The stronger light in the surrounding environment, the lower the resistance value the photo diode will read. By reading the photo diode's resistance value, we can work out the ambient lighting in an environment. The photo diode provided in the starter kit is a typical light sensor.
In this arduino tutorial, we will make an automatic light that can adjust itself according to the ambient lighting around it. When it is dark, the photo diode detects the change and triggers the light, and vice versa.
Components
DFRduino UNO R3 (similar as Arduino UNO R3)*1
prototype Shield  *1
Jumper Cables M/M *5
Ambient Light Sensor *1
Resistor 220R*1
5MM LED *1
Resistor 10K*1
Circuit
Be aware that photo diodes are polarized, just like LEDs, so they will only work if connected the correct way around.
The photo diode has to be connected with a 10k resistor rather than a 220Ω resistor.
Diagram of the photo diode circuit
Sample code 9-1:
// Project 9– Light the lamp
int LED = 13;                                     //define LED digital pin 13
int val = 0;                                         //define the voltage value of photo diode in digital pin 0
void setup(){
pinMode(LED,OUTPUT);                // Configure LED as output mode
Serial.begin(9600);                         //Configure baud rate 9600
void loop(){
val = analogRead(0);                     // Read voltage value ranging from 0 -1023
Serial.println(val);                         // read voltage value from serial monitor
if(val<1000){                                  // If lower than 1000, turn off LED
digitalWrite(LED,LOW);
}else{                                              // Otherwise turn on LED
digitalWrite(LED,HIGH);
delay(10);                                      // delay for 10ms
After uploading the code, you can shine a flashlight on the photodiode to alter the light levels in the environment. When it is dark, the should light up. When it is bright, the LED should turn off.
Code
A very brief explanation of the program:
Similar to the LM35 temperature sensor, the photo diode reads an analog signal so we don’t need to define “pinMode” in “serial.begin”.
We take the analog current data from the photodiode and compare it to a value of 1024 to make it digital. You can change this value if you like. Try playing with the serial monitor and seeing what outputs the photodiode gives. Then use this number you get here as the comparison number to alter the sensitivity of the circuit.
Circuit
Photo Diode
A photo diode is a semiconductor device that converts light into current.
The current is generated when photons are absorbed in the photo diode. The stronger the environment’s light, the lower the resistance value the photodiode will output. The analog value ranging from 0 to 1023 corresponds to voltage value ranging from 0 to 5V.
The input voltage Vin(5V) is connected to 2 resistors. By measuring the voltage of R2 as below, you can get the resistance value of photo diode.
In our arduino project, R1 is the 10k resistor and R2 is the photo diode. The resistance value of R2 in dark is so high that it almost reaches 5V. Once photons are absorbed, the value of R2 will decrease, and so will its voltage value. For this project it is preferable to use a fixed resistor ranging from 1k to 10k, otherwise the voltage dividing ratio is not obvious. This is why in this project we have used a 10k resistor for R1.
Last Arduino Tutorial 8: Vibration Sensor
Next Arduino Tutorial 10: How to Drive A Servo
