Forum >Romeo BLE V1 - Need help with code
RoboticsGeneral
userHead Account cancelled 2018-07-01 22:14:23 2466 Views1 Replies
I have this code and I can't make my Romeo V1 change speed. However I need help. How do I fix the code to be able to change speed.
I've enabled the code labeled ENA and ENB but nothing happens. I've removed the comment slashes but nothing happens when I change 255 to 100.
Any thoughts?
// Code for use with the DFRobot Romeo BLE V1 - motor controller for 2 DC motors - via usb
// Make sure DC motor polarity matches with motor terminal polarity on board + -
const int IN1 = 4; //One side motor 1
const int IN2 = 5;
const int IN3 = 6; //One side motor 2
const int IN4 = 7;
//const int ENA = 9;
//const int ENB = 3;
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
pinMode (IN3, OUTPUT);
pinMode (IN4, OUTPUT);
//pinMode (ENA, OUTPUT);
//pinMode (ENB, OUTPUT);
delay(5000);
//analogWrite(ENA, 100);
//analogWrite(ENB, 100);
digitalWrite(IN1, LOW); // Forwards
digitalWrite(IN2, HIGH);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
delay(3000);
//STOP
//analogWrite(ENA, 255);
//analogWrite(ENB, 255);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
delay(2000);
//analogWrite(ENA, 100); //Backwards
digitalWrite(IN1, HIGH);
digitalWrite(IN4, HIGH);
delay(3000);
//STOP
delay(2000);
//Turn RIGHT
delay(2000);
//STOP
delay(2000);
//Turn LEFT
delay(2000);
//STOP
delay(2000);
2018-08-02 20:07:31 If you change the PWM value in the code, the speed is not changed? userHeadPic robert.chen
