Forum >Dear Manager.
Dear Manager.
userHead Account cancelled 2018-07-03 06:43:50 3777 Views1 Replies
I purchased DFR 0508 Driver for operating bipolar stepper motor.
As a result of examining the datasheet, I have question about using this module without using fire beetle.
Do I have to use a fire beetle controller to operate stepper motor?
I want to use this motor driver with Arduino only.
I do not know how to use this motor drive
Give me information on how to do it
Thank you
2018-08-02 00:32:02 This motor shield is designed for firebeetle, so the pin placement is the same as firebeetle, if you want to use Arduino, why don't you just buy a motor shield for Arduino, it is easier to use, if you do want to use this shield, you can connect the shield like the wiring diagram in wiki to test if it is good to use. userHeadPic robert.chen
