SEN0188 Fingerprint "Communication error"
I have SENO18 Fingerprint like this: https://botland.com.pl/czytniki-linii-p ... alcow.html
I connected it with Arduino Micro acorrding to the instructions (connections as for photos in the attachment). Nexi I run enroll example and change pins number in line "SoftwareSerial mySerial(0, 1);" Next I upload the code to Arduino. When I use Adafruit Fingerprint Sensor Library v 1.1.0 then after running (in the serial port monitor) I have a message "Found fingerprint sensor!" (even when the sessor is physically unplugged!!!). Going forward, the next message is "Please type in the ID # (from 1 to 127) you want to save this finger as..." then i enter 12 for example. Then the sensor starts flashing in green light. Unfortunately, the next message is "Communication error". When I use Adafruit Fingerprint Sensor Library v 1.1.1 or v1.0.0 then after running I have a message ""Did not find fingerprint sensor"
Can you help me?
best regards,
Krzysztof
