Forum >EC Sensor Calibration Equations
userHead Account cancelled 2018-07-05 05:13:25 1929 Views1 Replies
maybe you can give me an explanation. It would be very helpful. I've bought the Analog electrical conductivity sensor.
I want to calibrate my EC Probe with the code from the wiki and the Sheme of calibration.
My question is now, how are the three equations are calculated out?
Do I need to change the equations with the results of my calibration progress?
And how can I do this?
What are those Values in this three equations? Like 6.84 or 64.32?
It would be nice, when i could get an answer how this is calculated out.
if(CoefficientVolatge<=448)ECcurrent=6.84*CoefficientVolatge-64.32; //1ms/cm<EC<=3ms/cm
else if(CoefficientVolatge<=1457)ECcurrent=6.98*CoefficientVolatge-127; //3ms/cm<EC<=10ms/cm
else ECcurrent=5.3*CoefficientVolatge+2278; //10ms/cm<EC<20ms/cm
Thanks for your help in advance.
2018-07-14 01:03:27 This equation got from experiment, which use the sensor to measure different solution to get the voltage and compare to the EC value to get the equation between voltage and EC. userHeadPic robert.chen
