Forum >ServoCds55 library for Digital dynamixel servo Shield : WORKING ANOTHER ID THAN 1 ??
I have been playing around with the library ServoCd55 in order to control my dynamixels from the smart arduino shield.
Refencing to that example code:
https://github.com/leffhub/ServoCds55/b ... 5_Test.ino
How is it possible to work with an ID other than 1, since a Reset() has to be called whenever switching mode?
line 72: myservo.Reset(servoNum); //Only Dynamixel AX need this instruction while changing working mode
And here on this line, the comments describing what Reset() does...
line 76: myservo.Reset(servoNum);//Restore ID2 servo to factory Settings ( ID:1 Baud rate:1000000)
Please could you answer me? Did I dfrobot something?
Your help would be much appreciate!!
Best,
Cécile
Best,
Cécile
