Forum >SEN0193
SEN0193
Hi, i want to know some things about this sensor like his resolution and the graph that describes the behavior, is this graph a straight or curve?, so when i saw the datasheet i found a rank ( Dry: (520 430] Wet: (430 350] Water: (350 260]), does the dfrduino's ADC give 260 when it's 0V and 520 when it's 3V?
thanks for your time.
2018-07-17 15:09:33
sansua90
Thanks, but do you know the resolution of the sensor?robert.chen wrote: ↑Thu Jul 12, 2018 9:59 amThe number 520 and 260 is just an example, if you follow the way in the wiki, the number maybe different, but close to those.
2018-07-13 01:59:56 The number 520 and 260 is just an example, if you follow the way in the wiki, the number maybe different, but close to those.
robert.chen
