Forum >Problems with reading success
Telematics General
userHead mklaenius 2014-01-31 07:30:10 4757 Views2 Replies
I am having a problem with reading values from the obd connectior. I do get like 12 % of reading successfully and rest fail. adapter is I2C model and connected to a golf mk6. I am reading 8 values one after another, do I have to make some delays to the process between reads or what?
2014-03-27 09:49:56 I'm also having slow obd.read when I'm reading more than 1 sensor on a 2011 Mazda 3.
It will run super fast with one PID but if I add 2 I get over 10 seconds before the data refreshes.
Here's a code snipet
    if (!obd.read(PID_SPEED, value)) {
        return;
    test_string = String(value);
    test_string = test_string + "      ";
    CTE_LCD.Put_Text(test_string,500,0,BVS_34);
    if (!obd.read(PID_COOLANT_TEMP, value)) {
        return;
    CTE_LCD.Put_Text(test_string,120,34,BVS_34);
    if (!obd.read(PID_ENGINE_LOAD, value)) {
        return;
    CTE_LCD.Put_Text(test_string,500,34,BVS_34);
    if (!obd.read(PID_THROTTLE, value)) {
        return;
    obd.read(PID_THROTTLE, value);
    CTE_LCD.Put_Text(test_string,120,68,BVS_34);
userHeadPic nicolas
2014-02-28 05:31:34 I just bought a elm327 bluetooth dongle and it works just fine. I have like 5 sec intervals between reads(I am aiming for 5 HZ however). What to do next? userHeadPic mklaenius
