Forum >Are Gravity Shields Needed for Gravity Sensors?
userHead Account cancelled 2018-07-16 07:44:22 6979 Views3 Replies
I am planning on using an Arduino Mega 2560 Rev 3 and an Adafruit Motor Shield v2.3 to control stepper motors. I also need to connect 3 Carbon Dioxide Sensors, and I would like to use Gravity: Analog Infrared CO2 Sensor for Arduino (SKU SEN0219), but I can't use the Gravity sensor shield. Is it possible to use that sensor without the Gravity shield, and if so, can you provide some guidance on how I would do so (any libraries and sample code would be greatly appreciated).
Thanks,
A
2018-07-19 23:47:54 You don't have to use the gravity sensor shield, you just need to make sure that the signal pin/VCC/GND are connected to the corresponding pins on Arduino. userHeadPic robert.chen
2018-07-19 23:40:11 You don't have to use the gravity sensor shield, you just need to make sure that the signal pin/VCC/GND are connected to the corresponding pins on Arduino. userHeadPic robert.chen
2018-07-19 23:40:03 You don't have to use the gravity sensor shield, you just need to make sure that the signal pin/VCC/GND are connected to the corresponding pins on Arduino. userHeadPic robert.chen
