Forum >Multi USB/RS232/RS485/TTL Converter on ARM
LattePandaGeneral
userHead lfxciii 2014-04-15 09:33:44 7663 Views4 Replies
I would just like to make sure if this converter is supported on ARM, anybody know?
Help appreciated
thank you
2014-04-16 01:17:36 its two different devices, one is an Intel x64 device, the other is an ARM x86 device userHeadPic lfxciii
2014-04-16 00:52:52 Uhm...are you sure it is Intel x64 and ARM x86?
Anyway, although they are using the same OS, but the driver should be different.
Please download the new driver for the Linux: http://www.ftdichip.com/Drivers/VCP.htm
userHeadPic Grey.CC
2014-04-15 21:47:17 Hi Grey
Thank you for replying. I use it on Linux with an Intel x64 and it works fine, but as soon as I use it on ARM x86, it doesnt work. should i update any drivers or something for Linux ARM?
thanks again.
userHeadPic lfxciii
2014-04-15 18:16:19 Hi,
The converter supports USB, TTL, RS232, RS485 interfaces between the system conversions.
It can convert one signal to the other signal protocol.
If your ARM device has one of these 4 kinds of signal output, it can convert to the other one.
userHeadPic Grey.CC
