Forum >Building Robopeak 2.8” USB TFT driver for Angstrom.
LattePandaGeneral
userHead ferite 2014-05-22 07:33:27 7684 Views2 Replies
Hi.
I am working on building the driver for a the Robopeak 2.8” USB TFT Touch Display. When I build the driver against Ångström (for x86 board) kernel header sources, I am getting this error:
* error: 'struct fb_info' has no member named 'fbdefio'*
After researching the problem, it seems caused for the lack of a setting in the kernel .config file:
CONFIG_FB_DEFERRED_IO=y
I tryed just to add the line to the file but it still does not work. I tryed to add the following section to video/Kconfig (this does not make difference either):
config FB_DEFERRED_IO
tristate
depends on FB
default n
I hope that someone could provide some advice on how could I add CONFIG_FB_DEFERRED_IO config to my system so I can finish the building process?.
Thanks.
2014-05-23 19:38:51 Ferite,
After a little digging around. I guess that it might depend on the Board support package.
Is it possible that parameter has changed name in Angstrom?
cheers^^
userHeadPic Jose
2014-05-22 23:17:24 Hi ferite,
The standard approach is to add some KConfig line in the kernel source to create a driver section which refer to the CONFIG_FB_DEFERRED_IO feature.
A simple way is :
Select the Displaylink display driver ( Device Drivers-> Graphics support -> Support for frame buffer devices-> Displaylink USB Framebuffer support) as an external module. By doing so, the above features will be selected by the menuconfiger.
userHeadPic csk
