Forum >DFR0144 v2.1 standoff mounting
2 standoffs and 2 screws were included in the package. there is insufficient clearance between the connector blocks and the mounting holes for the screw to be inserted correctly. The screw heads are too big. COM1 and COM4 need to be moved closer to the end of the board that has the servo power connector block.
2018-08-02 00:06:08 Thank you for the remind, we will report this problem to the product manager to modify it.
robert.chen
