Forum >UNO FUNCTIONING WITHOUT RTC???
Easy IoT General
userHead enmin1997 2018-07-31 04:54:09 4802 Views3 Replies
Hi I'm using a esp2866 board trying to connect to a DFRobot I2C RTC it works with a Arduino Uno but not when I tried with a esp2866 anyone knows how? Any help appreciated.
The connection I did on the esp2866 was GND=GND, VCC=3.3V, SDA=D2, SCL=D1
This is the code
#include <Wire.h>
#include <DS1307.h>
//Modify the following data
#define TIME_YR 18
#define TIME_MTH 7
#define TIME_DATE 30
#define TIME_DOW 1
#define TIME_HR 20
#define TIME_MIN 53
#define TIME_SEC 30
char* str[]={"Monday","Tuesday","Wednesday","Thursday","Friday","Saturday","Sunday"};//week
int rtc[7];
void showtime() //
RTC.get(rtc,true);
Serial.print( rtc[6]);
Serial.print("-");
Serial.print( rtc[5]);
Serial.print("-");
Serial.println( rtc[4]);
Serial.print( rtc[2]); /*HOUR MIN SEC */
Serial.print(":");
Serial.print( rtc[1]);
Serial.print(":");
Serial.println( rtc[0]);
Serial.println( str[rtc[3]-1]); /***WEEK**/
Serial.println("****");
{ Serial.begin(9600);
Wire.begin();
showtime(); //Output data from serial port
delay(1000);
2018-08-03 21:11:39 I'm constructing an assignment once I want my Arduino to execute some code at given hours of the day, as an instance one at 19:00 and some other at 06:00. I recognize that with an RTC module I'm able to do that without problems, however, how am I able to try this without an RTC module? I do not want to have to join my Arduino to a computer neither to the net. It does now not additionally ought to be particular, a few minutes off would be adequate.
My board is an Uno R3.
userHeadPic daisywalker407
2018-08-02 19:58:13 Hi thanks for the reply but I have changed to a UNO board instead. Now I have a new problem though my UNO board is functioning without a RTC but the code is suppose to only work with an RTC and it worked previously fine with one and stops when I detach the RTC now I'm getting these kind of readings
2165-45-45
45:85:85
Sunday
when I'm just attaching the UNO board and nothing else & even when I'm attaching it to the RTC. (The code is the same as above) What is happening???
userHeadPic enmin1997
2018-08-02 01:54:49 The I2C pins on ESP8266 are IO14 (SCL), IO2 (SDA), please use these two pins to have a test. userHeadPic robert.chen
