Forum >Temperature Sensor interferance with other Analog devices
RoboticsGeneral
userHead anonymous 2012-04-02 13:21:20 5881 Views3 Replies
If i use the Analog Linear Temp. Sensor (ALTS) in combination with the Analog ambient Light Sensor or the Analog Grayscale Sensor the ALTS gives erroneous and random readings. The ALTS is stable on its own (though not very accurate). I don't believe its the sketch becuase if i disconnect the Light or Grayscale sensor the ALTS will go back to reading consistently. I've tried changing the pause timing, power settings, which analog inputs are used for which device.
suggestions?
Thank you
2012-04-09 23:10:15 Cavu,
Could you provide a picture of your setup?
userHeadPic Hector
2012-04-08 11:48:39 Thanks for responding.  I thought about that and tried power from the USB, from a 6x1.5v and both together.
doesnt seem to make any difference. Any other ideas?
userHeadPic anonymous
2012-04-05 18:52:59 Hi Cavu,
What are you using to provide power? The temperature sensor is very sensitive to variations in voltage and current. If you do not provide sufficient or stable power it will cause fluctuations in its accuracy.
userHeadPic Hector
