Forum >Curies Nano V2.01 white ribbon cable connector
userHead Account cancelled 2018-08-30 16:23:31 1677 Views1 Replies
Hi there,
We just got a Curie Nano V2.01. There is this white ribbon cable connector at the back of the board. Can you provide details on this ribbon socket please? Perhaps its part number/datasheet/product link?
We are trying to put the Curie Nano in an enclosure and expose the USB port to the external via a panel mount USB female socket. Something like this: https://au.rs-online.com/web/p/products/9125114/
So we would like to get a ribbon cable, one end put into the white ribbon socket, the other end soldered to the wires coming out from the panel mount USB.
Cheers
2018-08-30 19:00:56 Hi。。。
I'm sorry to tell you that description of white ribbon cable at the back of the board. But I measured find it Pin description as same as USB interface at the front of the board.
Turn the board upside down and white ribbon cable close to yourself , Detailed descriptions are as follows:
From right to left, Pin1 is VCC,Pin2 is UD+,Pin3 is UD-,Pin4 is GND. My measurement were performed by reference to this Schematic link https://raw.githubusercontent.com/Ardui ... ematic.pdf.
Similarly, you can also view the this wiki get more information for Curie Nano V2.01 https://www.dfrobot.com/wiki/index.php/ ... U:_DFR0453
userHeadPic makermuyi
