Forum >WIFI Shield V3 : receive httprequest - sample code
userHead dakota77vfr 2018-09-07 11:44:00 3272 Views2 Replies
Hello
I would like to use Wifi shield V3 and Arduino UNO to receive httprequest from smartphone or laptop.
I can connect to the Wifi shield interface and set it to fixed IP adress 192.168.0.99
Ping is working.
I didn't find any documentation about the code I have to upload to receive data from Httprequest.
https://www.dfrobot.com/wiki/index.php/ ... KU:TEL0078
For example I want to send the string F1 : I send the httprequest 192.168.0.99/F1
Could you indicate where I can find a sample code ?
This is the working code used with an Arduino Uno wifi :
#include <SoftwareSerial.h>// import the serial library
#include <stdio.h> /* printf */
#include <stdlib.h> /* strtol */
#include <ArduinoWiFi.h>
#include <Wire.h>
char txc[20];
String readString; //create readString class
{ //======= Pour réception commandes en WIFI =============================
Serial.begin(9600);
Wifi.begin();
Wire.begin(4); // Rejoindre le bus à l'adresse #4
readString = "";
Serial.println("Arduino Wifi Started");
while(Wifi.available()){proc1(Wifi);}
void proc1(WifiData client) {
String command = client.readStringUntil('/');
readString = client.readStringUntil('/');
Serial.print("Received string : ");
Serial.println(readString);
client.println("Status: 200 OK\n");
Thanks for your help
2018-09-08 05:58:51 It is difficult to use a board with so little information.
I suppose I have to use a specific library...
userHeadPic dakota77vfr
2018-09-07 19:10:45 Hi
Sorry.There is no more sample code.
userHeadPic makermuyi
