Forum >Gravity: I2C DS1307 RTC Module - Trigger interrupt to wake up arduino from sleep mode
I would like to trigger an interrupt using the SQ pin on the Gravity: I2C DS1307 RTC Module. Can this be done using this module and if so which library is required? I haven't been able to make it work using the DS1307 library.
If this cannot be done with this module can you recommend one that can?
Many thanks
Heinz
Many thanks
Heinz
2018-09-12 19:31:32 Hi.
Accroding your description of your questions. I think you can using I2C SD2405 RTC Module SKU: DFR0469 implement trigger interupt to wake up arduino from sleep mode.
Hope help you.
makermuyi
Hope help you.
