Forum >Romeo v2.0 burnt
RoboticsGeneral
Romeo v2.0 burnt
userHead Adam 2014-01-27 01:42:00 7577 Views5 Replies
the Romeo, after being repeatedly used to drive 4 dc motors with this battery :
[url=http://hobbyking.com/hobbyking/store/__31315__Turnigy_9XR_Safety_Protected_11_1v_3s_2200mAh_1_5C_Transmitter_Pack.html]http://hobbyking.com/hobbyking/store/__31315__Turnigy_9XR_Safety_Protected_11_1v_3s_2200mAh_1_5C_Transmitter_Pack.html[/url]
suddenly got damaged. The atmega32u4 gets instantly hot after switching the power on, and the board is no longer recognised as a usb device.
Would could have been the reasons? How to prevent this from happening in the future?
Any questions for clarification are welcome.
2014-03-21 19:21:36 Hello,
How do you drive the Romeo V2 power supply?
Though the M_VIN? Did you connect the power cable with other pins?
userHeadPic Grey.CC
2014-03-21 17:18:17 The red one is a bluetooth mate gold.
The code for the uno is something like:
[code]
#include <SoftwareSerial.h>
int pin1 = 4;
int pin2 = 5;
int pin3 = 6;
int bluetoothTx = 2;  // TX-O pin of bluetooth mate, Arduino D2
int bluetoothRx = 3;  // RX-I pin of bluetooth mate, Arduino D3
int i;
char command;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  for(i=pin1;i<=pin3;i++){
    pinMode(i, OUTPUT);
    digitalWrite(i, LOW);
  Serial.begin(9600);
  bluetooth.begin(115200);  // The Bluetooth Mate defaults to 115200bps
  bluetooth.print("$");  // Print three times individually
  bluetooth.print("$");  // Enter command mode
  delay(100);  // Short delay, wait for the Mate to send back CMD
  bluetooth.println("U,9600,N");  // Temporarily Change the baudrate to 9600, no parity
  // 115200 can be too fast at times for NewSoftSerial to relay the data reliably
  bluetooth.begin(9600);  // Start bluetooth serial at 9600*/
  if(bluetooth.available()){
  command = bluetooth.read();
  bluetooth.println(command,DEC);
  if(command == '0')
  if(command == '1')
          digitalWrite(i, HIGH);
  if(command == '2'){
        digitalWrite(pin3, HIGH);
        for(i=pin1;i<=pin2;i++)
  if(command == '3'){
        digitalWrite(pin1, HIGH);
        for(i=pin2;i<=pin3;i++)
  if(command == '4'){
        digitalWrite(pin1, LOW);
        digitalWrite(pin2, HIGH);
        digitalWrite(pin3, LOW);
[/code]
And the Romeo code is something like:
[code] int E1 = 5;    //M1 Speed Control
int E2 = 6;    //M2 Speed Control
int M1 = 4;    //M1 Direction Control
int M2 = 7;    //M1 Direction Control
void stop(void)                    //Stop
  digitalWrite(E1,0);
  digitalWrite(M1,LOW);
  digitalWrite(E2,0);
  digitalWrite(M2,LOW);
void advance(char a,char b)          //Move forward
  analogWrite (E1,a);      //PWM Speed Control
  digitalWrite(M1,HIGH);
  analogWrite (E2,b);
  digitalWrite(M2,HIGH);
void back_off (char a,char b)          //Move backward
  analogWrite (E1,a);
  analogWrite (E2,b);
void turn_L (char a,char b)            //Turn Left
  analogWrite (E1,a);
  analogWrite (E2,b);
void turn_R (char a,char b)            //Turn Right
  analogWrite (E1,a);
  analogWrite (E2,b);
void setup(void)
  int i;
  for(i=4;i<=7;i++)
    pinMode(i, OUTPUT);
  Serial.begin(9600);      //Set Baud Rate
  Serial.println("Run keyboard control");
  digitalWrite(E1,LOW);
  digitalWrite(E2,LOW);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
//String Buttons[17] = {
//  "J2","J1",NULL,"S2","S1","UP","LEFT","DOWN","RIGHT","1","4","2","3","RZ1","RZ2","LZ1","LZ2"};
//  // Buttons Nmes
void loop(void)
  if(Serial.available()){
    //    String n = Buttons();
    char n=Serial.read();
      if(n != -1)
      switch(n)
      case '6'://Move Forward
        advance (255,255);  //move forward in max speed
        break;
      case '8'://Move Backward
        back_off (255,255);  //move back in max speed
        break;
      case '7'://Turn Left
        turn_L (100,100);
        break;
      case '9'://Turn Right
        turn_R (100,100);
        break;
      case '1':
        stop();
        break;
    else stop();
[/code]
userHeadPic Adam
2014-02-14 18:18:17 Hello Adam,
Sorry for the late reply,
The red one is a wireless?
You want to use UNO to make the remote communication receiver?
How do you drive these 4 motor?
userHeadPic Grey.CC
2014-01-29 04:33:54 Here are the pictures. The breakdown occurred after we put the boards together on top of each other. The lipo was connected to the boards via a breakout cable
Do you need a more accurate description?
userHeadPic Adam
2014-01-27 17:47:20 Hello Adam
It looks like the MCU has been broken.
Could you attach a photo about your hardware connection?
It will help us know what was happened?
userHeadPic Grey.CC
