Forum >Rate Sensor SKU: SEN0203 problem
userHead barnaimre86 2018-11-25 05:57:05 3141 Views3 Replies
i have followed the instruction
. included the library
.pinned in a0 5v and groun using the digital example from the library,
. the sensor is turned to digital,
.took down protection plastic, >
.using the wristholder,
. the led blinking as fast my heart
but apart from "waiting for valid data "nothing appaers. in analog mode using the analog code the numbers are changing in serialport, so wondering whats the problem?
2018-11-25 07:31:13 Im testing for 3 hours, and actually the analog doesnt works neither userHeadPic barnaimre86
2018-11-25 06:38:15 and in the analog code the numbers are either 1023 or 23-25 userHeadPic barnaimre86
2018-11-25 06:31:02 and "the LED is flashing regularly as my heartbeat" userHeadPic barnaimre86
