Forum >GPS/GPRS/GSM Module V3.0 arduino - Send sms with GPS data
Hi to all,
first of all, tank you for any suggestion.
I'm trying to create a Scratch for Arduino Uno able to do these simple steps:
1) activate GSM.
2) switch to GPS-mode.
3) wait for receiving NMEA signal from GPS
4) store a sample of NMEA string
5) activate GSM
6) send an SMS containing NMEA string.
NOTE: for my first step I need only to send a part of a simple NMEA string, witout formatting or choosing infromations (long-lat etc.)
I did this Scratch, merging some parts of wiki Scratchs and some little extra code.
some like:
[quote]TAT+CGPIPR=9600
Hello[/quote]
did you have some suggestion to do this goal?
1) activate GSM.
5) activate GSM
I received a sms on a cellphone, but I didn't received GPS string, but some part of AT command sended in the Scratch.// Product name: GPS/GPRS/GSM Module V3.0 // # Product SKU : TEL0051 // # Version : 0.1 // # Description: // # The sketch for driving the gsm mode via the Arduino board // # Steps: // # 1. Turn the S1 switch to the Prog(right side) // # 2. Turn the S2 switch to the Arduino side(left side) // # 3. Take off the GSM/GPS jumper caps from the Uart select // # 4. Upload the sketch to the Arduino board // # 5. Turn the S1 switch to the comm(left side) // # 7. RST the board // # wiki link- http://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051) char inChar; // byte for GPS Serial Read int index; // index for string (GPSdata) from GPS char GPSdata[300]; // string created with bytes (reading serial GPS) byte gsmDriverPin[3] = {3,4,5}; //The default digital driver pins for the GSM and GPS mode //If you want to change the digital driver pins //or you have a conflict with D3~D5 on Arduino board, //you can remove the J10~J12 jumpers to reconnect other driver pins for the module! void setup() { //Initialize the driver pins for GSM function: for(int i = 0 ; i < 3; i++){ pinMode(gsmDriverPin[i],OUTPUT); } // Initialize a buffer for received GPS data GPSdata for (int i=0;i<300;i++){ GPSdata[i]=' '; } // Output GSM Timing digitalWrite(5,HIGH); delay(1500); digitalWrite(5,LOW); // Enable GSM (Pin3,L)+ Disable GPS (Pin4,H): digitalWrite(3,LOW); digitalWrite(4,HIGH); delay(2000); //set the baud rate Serial.begin(9600); delay(15000); // time suggested by wiki } // end "void setup" void loop(){ // activate GPS with AT Commands // NOTE: as suggested in "How to drive the GSM Mode via USB port" of wiki, // you have to send AT commands in GSM-mode, then switch in GPS-mode. Serial.print("AT"); delay(2000); Serial.println("AT+CGPSIPR=9600");// (set the baud rate) delay(1000); Serial.println("AT+CGPSPWR=1"); // turn on GPS power supply delay(1000); Serial.println("AT+CGPSRST=1"); //reset GPS in autonomy mode // Enable GPS (Disable GSM) digitalWrite(3,HIGH); digitalWrite(4,LOW); //delay to assure GPS gets date. delay(60000); // GPS COORDINATES ACQUISITION // Initialize a buffer for received GPS data GPSdata for (int i=0;i<300;i++){ GPSdata[i]=' '; } // reset index index=0; // read Bytes from GPS: inChar = Serial.read(); // See if the port is empty yet while (inChar == -1) { delay(100); } // until buffer is full (GPSdata[300]): while (index<300){ inChar = Serial.read(); GPSdata[index] = inChar; index = index+1; } // Enable GSM (Pin3,L)+ Disable GPS (Pin4,H): digitalWrite(3,LOW); digitalWrite(4,HIGH); // send AT Commands (for SMS) Serial.println("AT"); //Send AT command delay(2000); Serial.println("AT"); delay(2000); Serial.println("AT+CMGF=1"); delay(1000); Serial.println("AT+CMGS=\"0039**********\""); //Change the receiver phone number delay(1000); // send GPS store data: for (int i=0;i<300;i++){ Serial.print(GPSdata[i]); } // add a word: Serial.print("HELLO");//the message you want to send delay(1000); Serial.write(26); // ASCII Character = "CTRL-Z" while(1); }
some like:
Hello[/quote]
2015-01-25 18:56:43 hi! could anyone help me with this problem? i used this code
//Init the driver pins for GSM function
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
// Use these commands instead of the hardware switch 'UART select' in order to enable each mode
// If you want to use both GMS and GPS. enable the required one in your code and disable the other one for each access.
digitalWrite(3,LOW);//enable GSM TX?RX
digitalWrite(4,HIGH);//disable GPS TX?RX
and the result is:
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
then, theres no response
I supplied the module with the port of usb and a 7.5v 500mA
moomoy071410
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
and the result is:
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
and the result is:
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
moomoy071410
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
and the result is:
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
2014-12-09 07:12:13 Hi Grey,
I press "z" and "ctrl" buttons simultaneously on keyboard.am I right?
alright, I will try it later.
Thanks,
JJ
JJ
Thanks,
JJ
Thanks,
JJ
JJ
Thanks,
JJ
2014-12-09 06:14:11 Hi JJ
How do you implement the action “Ctrl+Z”. I guess it will be some problem.
Could you try the Arduino SMS sample code:
[quote]+CMTI: "SM",1[/quote]
Try to use the AT command "AT+CMGR=1" to read it.
All the command is included in the datasheet.
Grey.CC
And I want to tell you that there was a new message when you were testing the module byte gsmDriverPin[3] = { 3,4,5};//The default digital driver pins for the GSM and GPS mode //If you want to change the digital driver pins //or you have a conflict with D3~D5 on Arduino board, //you can remove the J10~J12 jumpers to reconnect other driver pins for the module! void setup() { //Init the driver pins for GSM function for(int i = 0 ; i < 3; i++){ pinMode(gsmDriverPin[i],OUTPUT); } digitalWrite(5,HIGH);//Output GSM Timing delay(1500); digitalWrite(5,LOW); digitalWrite(3,LOW);//Enable the GSM mode digitalWrite(4,HIGH);//Disable the GPS mode delay(2000); Serial.begin(9600); //set the baud rate delay(5000);//call ready delay(5000); delay(5000); } void loop() { Serial.println("AT"); //Send AT command delay(2000); Serial.println("AT"); delay(2000); //Send message Serial.println("AT+CMGF=1"); delay(1000); Serial.println("AT+CMGS=\"1580xxxxx71\"");//Change the receiver phone number delay(1000); Serial.print("HELLO");//the message context delay(1000); Serial.write(26); while(1); }
Grey.CC
2014-12-08 03:17:50 hi Grey,
Yeap, I follow the instructions written in WIKI,
S1: Arduino
S2: COMM
Uart: Middle (it doesn't change)
But in the end, it did not show in receiver's mobile phone although I get the AT results like WIKI shown
Next, today I tried
// # Version : 0.1
// # Description:
// # The sketch for driving the gsm mode via the USB interface
// # Steps:
// # 2. Turn the S2 switch to the USB side(left side)
// # 3. Set the UART select switch to middle one.
// # 4. Upload the sketch to the Arduino board(Make sure turn off other Serial monitor )
// # 6. RST the board
// # wiki link- https://www.dfrobot.com/wiki/index.php/G ... U:TEL0051)
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
I curious why it enables me send "one time message" to the receiver's phone, the second times fails forever. The serial monitor shows me this:
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
OK
ERROR
AT+CMGS="016652xxx93"
> SDSD.
+CMGS: 235
OK
AT+CMGS="0177xx8199"
> XIaaN.
ERROR
+CMTI: "SM",1
AT+CMGS="0166xx1093"
> SDS.
ERROR
hmm, is there any setting requires when send the second times of message to any receiver phone? Since i remains same setting as the 1st time. I tried most of brands simcard, they work same, one time success only. Second time, have to restart all the stuff just can send again.
i use 9V/350mA power adapter.
Thanks for replY.
Best regards,
JJ
JJ
S1: Arduino
S2: COMM
Next, today I tried
// # Version : 0.1
// # Description:
// # Steps:
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
OK
ERROR
> SDSD.
+CMGS: 235
OK
> XIaaN.
ERROR
+CMTI: "SM",1
> SDS.
ERROR
Thanks for replY.
Best regards,
JJ
S1: Arduino
S2: COMM
Next, today I tried
// # Version : 0.1
// # Description:
// # Steps:
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
OK
ERROR
> SDSD.
+CMGS: 235
OK
> XIaaN.
ERROR
+CMTI: "SM",1
> SDS.
ERROR
Thanks for replY.
Best regards,
JJ
JJ
S1: Arduino
S2: COMM
Next, today I tried
// # Version : 0.1
// # Description:
// # Steps:
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
delay(1500);
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
OK
ERROR
> SDSD.
+CMGS: 235
OK
> XIaaN.
ERROR
+CMTI: "SM",1
> SDS.
ERROR
Thanks for replY.
Best regards,
JJ
2014-12-02 22:54:49 Hi JJ,
For Arduino mode,
It should be
S1: Arduino
S2: COMM
Could you attach a photo about your module switches?
Grey.CC
For Arduino mode,
It should be
S1: Arduino
S2: COMM
For Arduino mode,
It should be
S1: Arduino
S2: COMM
Grey.CC
For Arduino mode,
It should be
S1: Arduino
S2: COMM
2014-12-02 09:15:10 Hi all,
Thanks Grey. May I ask I had tried the code from https://www.dfrobot.com/wiki/index.php/G ... TEL0051%29
under section of
"How to drive the GSM Mode via Arduino board"
There have no response to the receiver although I get the output on Serial monitor as shown in Figure shown in the page there.
Moreover, when i tried the
It works fine as the receiver receive my message. What is the problem behind it? ???
Thanks for reply.
Best regards,
JJ
JJ
under section of
Thanks for reply.
Best regards,
JJ
under section of
Thanks for reply.
Best regards,
JJ
JJ
under section of
Thanks for reply.
Best regards,
JJ
2014-11-29 23:49:36 Hi JJ,
They are OK. But it is better to use a lower voltage one, like 7.4V~9V.
What the best is the suitable. It doesn't need too high voltage.
For example~ our [urlhttp://www.dfrobot.com/index.php?route=product ... ption=true]7.4V lipo battery[/url]. 2200mha
Grey.CC
Grey.CC
2014-11-27 01:27:49 Hi,
currently, I looking for any portable battery for supply GPS/GPRS/GSM shield+UNo+LCD. May I ask ask can anyone give me some suggestion? As the normal battery is insufficient since it give 9V battery that has only 300mAh.
I have few choices as below, can you guys tell me is they suitable for my project?
1) 11.1V 1200mAH 25C Lipo Battery
2) WLtoys V912 RC Heli Spare Part-20-2s 1000mAh Upgrade Lipo Battery (7.4V/1000mAh )
3) MJX F49 Spare Part-15-2S 7.4v 1500mah Lipo Battery
Last question, is there said the higher the voltage, the better the operation is has?
thanks for replys. Appreciated ^_^
Best regards,
JJ
JJ
Best regards,
JJ
Best regards,
JJ
JJ
Best regards,
JJ
2014-02-09 21:17:41 Hello Kappa,
How are you testing this code?
What power supply are you using?
Are you indoors or outdoors?
Looks like it might be a problem with your initialization sequence. My guess is that the At commands are stuck.
I suggest you to double check the switch status, and disable the Serial from the computer if you are using it. Also, make sure the shield is active while testing this.
Let us know the LED status at each step.
Jose
Jose
2014-02-08 17:51:12 Hi to all,
1) activate GSM.
5) activate GSM
some like:
Hello[/quote]
kappa
1) activate GSM.
5) activate GSM
I received a sms on a cellphone, but I didn't received GPS string, but some part of AT command sended in the Scratch.// Product name: GPS/GPRS/GSM Module V3.0 // # Product SKU : TEL0051 // # Version : 0.1 // # Description: // # The sketch for driving the gsm mode via the Arduino board // # Steps: // # 1. Turn the S1 switch to the Prog(right side) // # 2. Turn the S2 switch to the Arduino side(left side) // # 3. Take off the GSM/GPS jumper caps from the Uart select // # 4. Upload the sketch to the Arduino board // # 5. Turn the S1 switch to the comm(left side) // # 7. RST the board // # wiki link- https://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051) char inChar; // byte for GPS Serial Read int index; // index for string (GPSdata) from GPS char GPSdata[300]; // string created with bytes (reading serial GPS) byte gsmDriverPin[3] = {3,4,5}; //The default digital driver pins for the GSM and GPS mode //If you want to change the digital driver pins //or you have a conflict with D3~D5 on Arduino board, //you can remove the J10~J12 jumpers to reconnect other driver pins for the module! void setup() { //Initialize the driver pins for GSM function: for(int i = 0 ; i < 3; i++){ pinMode(gsmDriverPin[i],OUTPUT); } // Initialize a buffer for received GPS data GPSdata for (int i=0;i<300;i++){ GPSdata[i]=' '; } // Output GSM Timing digitalWrite(5,HIGH); delay(1500); digitalWrite(5,LOW); // Enable GSM (Pin3,L)+ Disable GPS (Pin4,H): digitalWrite(3,LOW); digitalWrite(4,HIGH); delay(2000); //set the baud rate Serial.begin(9600); delay(15000); // time suggested by wiki } // end "void setup" void loop(){ // activate GPS with AT Commands // NOTE: as suggested in "How to drive the GSM Mode via USB port" of wiki, // you have to send AT commands in GSM-mode, then switch in GPS-mode. Serial.print("AT"); delay(2000); Serial.println("AT+CGPSIPR=9600");// (set the baud rate) delay(1000); Serial.println("AT+CGPSPWR=1"); // turn on GPS power supply delay(1000); Serial.println("AT+CGPSRST=1"); //reset GPS in autonomy mode // Enable GPS (Disable GSM) digitalWrite(3,HIGH); digitalWrite(4,LOW); //delay to assure GPS gets date. delay(60000); // GPS COORDINATES ACQUISITION // Initialize a buffer for received GPS data GPSdata for (int i=0;i<300;i++){ GPSdata[i]=' '; } // reset index index=0; // read Bytes from GPS: inChar = Serial.read(); // See if the port is empty yet while (inChar == -1) { delay(100); } // until buffer is full (GPSdata[300]): while (index<300){ inChar = Serial.read(); GPSdata[index] = inChar; index = index+1; } // Enable GSM (Pin3,L)+ Disable GPS (Pin4,H): digitalWrite(3,LOW); digitalWrite(4,HIGH); // send AT Commands (for SMS) Serial.println("AT"); //Send AT command delay(2000); Serial.println("AT"); delay(2000); Serial.println("AT+CMGF=1"); delay(1000); Serial.println("AT+CMGS=\"0039**********\""); //Change the receiver phone number delay(1000); // send GPS store data: for (int i=0;i<300;i++){ Serial.print(GPSdata[i]); } // add a word: Serial.print("HELLO");//the message you want to send delay(1000); Serial.write(26); // ASCII Character = "CTRL-Z" while(1); }
some like:
Hello[/quote]
