Forum >Impedance Question on Gravity Analog Electrical Conductivity Sensor
Hi, I have a Gravity: Analog Electrical Conductivity Sensor SKU:DFR0300. This is the K=1 sensor.
I need to shorten the BNC cable for my application and was going to put a new BNC connector. Would a 50 ohm connector work or do I need 75 ohm? Also would the same one work for the other K models (the K=10, etc....)?
2019-01-02 23:23:23 Hi, can I know why do you want to short the BNC connector? Actually the 50 ohm or 75 ohm are both ok to use, and if you want to use different K models, there is one EC sensor with K=10 https://www.dfrobot.com/product-1797.html
robert.chen
