Forum >DFR0264 Battery Connector and Output Current
userHead Account cancelled 2019-01-01 05:31:49 1179 Views1 Replies
Hi there, I bought the DFR0264 and my battery connector doesn't seem to fit, could someone tell me what type of connector is on the board?
Also I was wondering what is the Current output from this board, since it charges at 500mAh does that mean the output will also be 500mAh or is it what the battery is rated for?
2019-01-02 22:51:35 Hi
I think the connector is 2-pin ph2.0
The output current is depends on the solar panel, if the solar panel has enough power, the maximum output current is 500mA.
userHeadPic robert.chen
