Forum >Maqueen Robot Car (V3.0) schematics
RoboticsGeneral
userHead stephane.driussi 2019-01-07 09:59:41 11402 Views6 Replies
I have purchased the Micro kit: Maqueen Robot Car and I have received the release V3.0 of ROB0148. I have found schematics of the V2.0 but not V3.0. I'm trying to connect a servo on P1 connector and I think there is a conflict with the ultrasound proximity sensor.
Regards
2019-06-06 09:25:40
stephane.driussi wrote:
Sun Jan 06, 2019 5:59 pm
Regards
Where can i find the schematics of the Maqueen?
Thanks.
Jack.
userHeadPic anonymous
2019-03-18 22:48:36 Yes, if you don't use the ultrasonic sensor, you can use other devices with P1 and P2. userHeadPic robert.chen
2019-03-14 05:50:19 If I remove the ultrasonic sensor ( too bad it is partly blocking the microbit display - may remove it by using extension cables) ... can i use the P1 and P2 for another device ? userHeadPic hulst029
2019-01-08 02:58:37 it's for fun, my 13 years child really like it. userHeadPic stephane.driussi
2019-01-07 23:47:41 Hi, we did not change the hardware of V3.0, P1 and P2 is usded for ultrasonic sensor, so the servo can not be used on P1 or P2. but we are upgrade Maqueen now, the later version, we will have two ports for servos.
By the way, Can I know is the Maqueen you bought just for fun or you want to apply it to any area, do you have any more demand for this kit?
