Forum >How to ArduinoWifi shield ?
2019-01-18 23:56:13 When start use of this shield, the IP address is 10.10.100.254, which you need to type in your explorer. After that you need to check the ip address of your local Wifi and make sure the IP address is in the same range as your local IP.
robert.chen
