Forum >DFR0499 64x64 LED display
I have correctly wired up (checked it 3 times) the DFR0499 to a Mega2560 and loaded the sample code found here: https://www.dfrobot.com/wiki/index.php/ ... KU:DFR0499
But when I run the code, the display looks to be only using rows 17-32 and 33 - 48. The words scroll and change but the other 2 areas always a black. I am not sure if I have a defective LED board or if something else is wrong. Has anybody seen this?
Also, where is the documentation found on the library calls in the samples? I have the library but no API documentation to use it.
Hopefully somebody can point me in the right direction?
2019-02-13 13:13:31 Good news I found the issue. Not all Mega2560's are created equal. I accidentily ordered a Bluno Mega which said it was a Mega 2560 but it is not. Once I received the 'real' one the project works as designed.
jentronicseng
