Forum >[CLOSED] USB not showing up in Arduino IDE ports
Bluno General Arduino
userHead tiojoca 2019-02-06 04:30:26 2964 Views1 Replies
Hi everyone,
I've got some new Bluno boards and I'm trying to connect with Arduino IDE but the "/dev/cu.usbmodemfd121" that appeared previously with my older boards in Menu > Tools > Ports is not there (it only shows "/dev/cu.Bluetooth-Incoming-Port"). Anyone has any idea why this might be happening and what can I do to fix it?
Thanks in advance!
2019-02-08 03:11:10 After testing with 2 differents computers, more than 2 Bluno boards of different versions and 3 USB cables, turns out the issue were the cables themselves. userHeadPic tiojoca
