Forum >need helpwith a pid control at a home care robot
RoboticsGeneral
userHead Account cancelled 2019-02-06 07:50:33 5030 Views0 Replies
hi at all, actually i´m working with the HCR Mobile Robot Platform from DFRobot with an Arduino Romeo.
https://www.dfrobot.com/product-361.htm ... gKOcPD_BwE
To control the robot in one way i found the following example:
//The sample code for driving one way motor encoder
#include <PID_v1.h>
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 3;//B pin -> the digital pin 3
int E_left =5; //The enabling of L298PDC motor driver board connection to the digital interface port 5
int M_left =4; //The enabling of L298PDC motor driver board connection to the digital interface port 4
byte encoder0PinALast;
double duration,abs_duration;//the number of the pulses
boolean Direction;//the rotation direction
boolean result;
double val_output;//Power supplied to the motor PWM value.
double Setpoint;
double Kp=0.6, Ki=5, Kd=0;
PID myPID(&abs_duration, &val_output, &Setpoint, Kp, Ki, Kd, DIRECT);
Serial.begin(9600);//Initialize the serial port
pinMode(M_left, OUTPUT); //L298P Control port settings DC motor driver board for the output mode
pinMode(E_left, OUTPUT);
Setpoint =80; //Set the output value of the PID
myPID.SetMode(AUTOMATIC);//PID is set to automatic mode
myPID.SetSampleTime(100);//Set PID sampling frequency is 100ms
EncoderInit();//Initialize the module
advance();//Motor Forward
abs_duration=abs(duration);
result=myPID.Compute();//PID conversion is complete and returns 1
if(result)
Serial.print("Pluse: ");
Serial.println(duration);
duration = 0; //Count clear, wait for the next count
void EncoderInit()
Direction = true;//default -> Forward
pinMode(encoder0pinB,INPUT);
attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
int Lstate = digitalRead(encoder0pinA);
if((encoder0PinALast == LOW) && Lstate==HIGH)
int val = digitalRead(encoder0pinB);
if(val == LOW && Direction)
Direction = false; //Reverse
else if(val == HIGH && !Direction)
Direction = true; //Forward
encoder0PinALast = Lstate;
if(!Direction) duration++;
else duration--;
void advance()//Motor Forward
digitalWrite(M_left,LOW);
analogWrite(E_left,val_output);
void back()//Motor reverse
digitalWrite(M_left,HIGH);
void Stop()//Motor stops
digitalWrite(E_left, LOW);
my problem is, that i want to control the robot not only in one way, rather in two. so i want to switch between function "advance()", "reverse()" and "stop()", maybe with a switch-case instruction.
I tried, too, but the regulation does not work as soon as I try it this way:
if (Serial.available()){
if (x =='1'){
if(result)
if (x =='2'){
reverse();//Motor Backyard
if(result)
Please help!
