Forum >3.3v logic with Bluno Beetle
Bluno General Arduino
userHead Account cancelled 2019-02-22 04:52:10 3278 Views1 Replies
I have a particulate sensor im trying to hook up with the bluno beetle. It is powered 5v but 3.3v logic will this work or do i need to use a Logic Level Converter?
2019-02-22 17:27:22 The working voltage of Bluno Beetle is 5V, if your sensor's working voltage is 3.3V, you need to use a logic level converter in case the break of the sensor. userHeadPic robert.chen
